Old 03-02-2021, 10:38 PM #1
WRfarmer WRfarmer is offline
WRfarmer is on a distinguished road
No good deed goes unpunished
I loaned my 2000 4runner to my daughter in law and she wrecked it when she spun out during a snow storm and hit the center concrete divider on the highway. She is ok but the yota look a beating. The drivers front tire is toed in drastically while the passenger side is straight. I've looked under it and can't see anything bent. I know i'm asking opinions on something you can't see but what would possibly cause the right wheel to toe in so much? I'm looking for suggestions so I have a starting point before I give in and take it to a shop.
WRfarmer is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:38 PM #2
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
I'm glad she is ok. Scary situation.
I'd start by jacking up the front end and start rocking the tires left to right and up to down. See what's tight and what's loose. While it's jacked up I'd also give everything that's suspension related a good tug and visual inspection. Compare each side if you aren't too familiar with it. Something is bent or broke.
Could be a number of things but my guess would be Inner and or outer tie rods might be toast.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:39 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
The main part is that she's ok and thats good. I facepalmed because without 4WD on (if you have it) and summer tires equipped, the 4Runner kinda doesn't like the snow if the throttle is not well controlled. I haven't worked the suspension on mine but maybe the control arms or tie rod ends could be damaged.
2000 4Runner Limited 4x4 V6
Old 03-02-2021, 11:48 PM #4
HiLife HiLife is offline
Metal can always be reworked or straightened. Great that she is ok.
I would be guessing the spindle and/or your tie rod section would be bent and require replacing. It's not too bad of a job if you have the tools and can be done in a driveway.
Old 03-03-2021, 01:20 AM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
hitting a concrete divider on a hiway at speed could cause more damge than the eye can easily see
Old 03-03-2021, 01:25 AM #6
spartacus's Avatar
spartacus's Avatar
Glad she is ok. The most obvious toe issue would be the tie rod is bent. Also the impact could have moved the cam bolts out of alignment. A alignment would take care'of that.
Old 03-03-2021, 11:31 PM #7
Thanks all! I'll take it in and let an expert take a look at it. Hopefully it's something cheap (because I am).
Old 03-04-2021, 12:23 PM #8
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
My family laughs at me because I've never loaned out my "old" 4runner, which is at this point becoming practically irreplaceable.
Glad she's ok.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 01:09 AM #9
TheExplorer's Avatar
TheExplorer TheExplorer is offline
TheExplorer is on a distinguished road
A number of years ago with another vehicle. I hit black ice and went into the curb. I actually bent the lower control arm and had to replace it. So this could be something to look at.
Get out and explore the outdoors as much as possible
TheExplorer is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 10:33 PM #10
Words of wisdom would be appreciated
I have decided to jump in and replace the LCA, inner and outer tie rod ends, upper and lower ball joints and the sway bar ends on both sides. I'm going to order the parts from either Parts Geeks or Detroit Axel because they are 1/3 of the price of the stealership. The boot is torn on the passenger side axle that is less than a year old so I might as well replace the boot or the entire axle. Any words of wisdom would be greatly appreciated. I've watched videos on the ball joints and they don't look to hard to do but I'm not sure about the inner tie rod.
Old 03-19-2021, 08:52 AM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
OEM LBJ's and LBJ bolts are worth the price you pay for how long they last. If you have the time and patience rebooting an OEM axle is the preferred way to go for longevity.
Axle boot kit for one axle 04438-35061
Both LBJ's (no cotter pins or castle nuts) 04005-02235
Castle nut (each) 90171-A0005
LBJ bolts (each) (requires 8) 90080-10066 flanged bolt will not work with the LBJ covers 1996-2000 OR 90119-10933 bolt with washer 2001-2002
Old 04-13-2021, 06:43 PM #12
No Good Deeds
The local mechanic wanted $900 to replace the driver side LCA so I've collected all the parts to do both sides of the Yota (less than $400) upper and lower control arms, ball joints, sway bar link and inner and outer tie rods. I was watching a video on removing the LCAs and it said I have to remove the rack first because the bolts for the LCAs are long and won't clear if I don't. Has anyone done this? Can I just loosen the rack bolts enough to get get the LCA bolts out and back in?
Old 04-13-2021, 06:57 PM #13
spartacus's Avatar
spartacus's Avatar
I think if you loosen the rack you should be good.
Here is a long video just forward it to the part that you want to see. it's pretty detailed.
https://www.google.com/url?sa=t&sour...XiSivMTR6n8Yuv
Old 04-13-2021, 06:58 PM #14
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
The video is correct, you have to move the rack out of the way to get the rear lower bolts out. Would be a good time to consider new rack bushings since you are in there.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 08:24 PM #15
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Just a word (or two) of caution. Detroit Axle part are cheap for a very good reason: They're not very good. Said another way, they're not very durable and don't generally last very long. Be forewarned.
Too Stroked is offline   Reply With QuoteReply With Quote
bent , give , looked , opinions , suggestions
Light racing UCA's good or no good ... srs034runner 4th Gen T4Rs 4 03-11-2016 09:58 PM
What should I look for diagnotic tests (battery good, ignition good, no start sounds) foo 3rd gen T4Rs 6 08-12-2015 06:28 PM
Good Deed for the Day..... Canazes9 Off Topic 10 08-30-2013 11:35 AM
A Good Deed 1engineer 5th gen T4Rs 68 10-28-2012 10:58 AM
Doing a good deed. darktiger 4th Gen T4Rs 5 01-03-2004 02:01 PM
