Old 03-04-2021, 10:59 AM #1
MtnT4R's Avatar
MtnT4R MtnT4R is offline
MtnT4R is on a distinguished road
MtnT4R's Avatar
P1783 code- 4WD Position Sensor?
Does anyone have any experience with this code? All I could find online and T4R search is that this code was specifically added to 2002 4Runners, and doesn't apparently exist in any other models of 3rd gens.
my 4WD actuator failed last year, so I replaced the front diff ADD actuator and swapped the original transfer case for a junkyard part that worked flawlessly for about 10 months until it started throwing this P1783 code, and now it takes 5ish miles of driving at different speeds to get the AWD to engage/disengage. I've tried all the tricks to get it to engage faster, but nothing seems to work other than extensive mileage- even putting the vehicle into low range just results in 2WD low, there is no automatic change to 4WD thats supposed to happen.
My shop said there is not a specific 4WD position sensor to replace either.
'02 SR5
"Gas pedal's on the right.'
~Logan
MtnT4R is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 01:03 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I have no first hand experience with that code, but typically electronically actuated transfer cases monitor the 4wd position internally to the actuator. Sorry I can't be of any more help than that.
EDIT: Ignore me, I misunderstood what you wrote.
Old 03-04-2021, 03:10 PM #3
spartacus's Avatar
spartacus's Avatar
Fsm pages indicate transfer neutral switch malfunction. attached pages might help.
P1783 code- 4WD Position Sensor?-1-jpg  P1783 code- 4WD Position Sensor?-2-png  P1783 code- 4WD Position Sensor?-3-jpg
Old 03-11-2021, 03:47 PM #4
MtnT4R's Avatar
MtnT4R's Avatar
Thanks for the diagram! When work calms down a little I'll check this out and report back.
'02 SR5
~Logan
4wd , actuator , code , low , p1783
Cam shaft position sensor vs. O2 Sensor Swimupstream 4th Gen T4Rs 0 10-15-2018 05:46 PM
Wiring diagram for gas pedal position sensor and brake pedal sensor? Seymore Butts 4th Gen T4Rs 0 05-23-2018 03:38 PM
Code 7 Throttle Position sensor vctehbro Classic T4Rs 1 04-28-2016 10:30 AM
p0340 code camshaft position sensor bikerjosh 3rd gen T4Rs 1 09-29-2013 06:57 PM
Throttle Position Sensor code octanejunkie 3rd gen T4Rs 2 05-20-2013 02:34 PM
