Old 03-04-2021, 06:35 PM #1
PHGen3 PHGen3 is offline
PHGen3 is on a distinguished road
Steering box adjustment?
I am wondering if anyone has done any adjustment to their steering box. I see is has what appears to be an adjustment screw on top of the unit. I used to have a Triumph TR4 with a similar box and adjustment screw. If one tightened the screw about 1/8th of a turn it would take some play out if the steering.
My play is not real bad, maybe about 1/2" in the steering wheel at speed after it has warmed up. The vehicle tracks straight, but you can not let your attention lapse. I understand tie rod bushings are another possibility, they don't appear to be too bad.
Any experiences?
Thanks,
PHGen3
PHGen3 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 06:56 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
The TR4 looks nice, I had a 72' Triumph Spitfire, ah Lucas the prince of darkness, don't miss those electricals.
There is no steering box on the 3rd gen just a steering rack, you can adjust the rack tension but it doesn't usually remove steering play just stiffness and rebound, the most common cause of steering play on these is the steering rack bushings, once they wear the rack will shift back and forth on its bushings which is easy to confirm with a steering wheel wiggle while observing the rack for movement. Other possibilities in likely order would be inner and outter tie rods, LBJ, LCA bushings, and steering shaft or steering shaft ujoints, and maybe an upper control arm issue.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 10:00 PM #3
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
Another point of slop on the steering is the slip joint in the column itself. You can reach under the column and turn the wheel just a little back and forth, and if there's play you'll feel it on the joint with your other hand.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 01:24 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
energy suspension rack bushing took out my free play
this current ride will get them when I rebuild the front suspension this summer, not gonna even check if bad, just gonna do them. Amazon had them cheapest a few years ago when I did my last 4runner. Note however, that amazon in the past has not had correct listings for energy suspension for the 4runners on some parts. Look up the part # at other sites, then compare prices, and use the part # at amazon...worked for me.
Old 03-05-2021, 07:29 PM #5
Thanks everyone for the ideas. It looks like the steering rack bushings and the column slip joint would be good places to check.
adjustment , box , play , screw , steering
Steering Wheel Adjustment BoomerBob 3rd gen T4Rs 24 07-05-2019 04:31 PM
Solid rack guide update in steering rack needs continual adjustment floatingkiwi 3rd gen T4Rs 13 03-20-2017 01:04 PM
95 4runner: steering rotation limit adjustment ccoker Classic T4Rs 0 11-17-2015 08:56 PM
Steering wheel adjustment?? T4Ralabama 3rd gen T4Rs 2 11-23-2009 09:42 AM
Important Steering Shaft Adjustment for Body Lifts 4route Off-Roading 9 07-15-2007 02:23 AM
