Old 03-04-2021, 10:07 PM #1
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Intermittent weak brake pedal
Wife came home today complaining of an intermittent weak brake pedal... told me today and mentioned it’s happened before.
Symptom: little to no pedal... let off and push again and it feels and stops normally. She thought it mostly happens when slow rolling like stop-and-go at a light.
In my test drive it does feel like the pedal may be a little soft but I could replicate what she described... maybe I should get a job at the dealer Intermittent weak brake pedal
I’m thinking to flush the fluid, maybe suspect the master cylinder... booster.
Hoping the 3rd gen family will pipe in if they have any thoughts or have had similar issues
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 10:48 PM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
My brake pedal has a longer travel than usual but bites very hard when it grabs. I would maybe flush the brake fluid first if its spongier than usual. Lots of people snag good boosters at the scrapyard for cheap.
2000 4Runner Limited 4x4 V6
Old 03-04-2021, 11:07 PM #3
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Would a bad booster make a soft or a stiff pedal?
Old 03-04-2021, 11:49 PM #4
I don't think it would be. A bad brake booster could stiffen the pedal or something, not sponge it up (well thats what I read on Google, I have not dealt with one). It could be your master cylinder going out. Hold the brake pedal and see if it loses pressure and goes down. If not, maybe flush the fluid and see what happens.
EDIT: I didn't read it carefully. A bad booster would stiffen the pedal.
Old 03-05-2021, 12:00 PM #5
spartacus's Avatar
spartacus's Avatar
Checking the brake lines for degradation and bulges would be a good as well.
Old 03-05-2021, 02:55 PM #6
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I'm just not entirely sure what symptoms are being described. Little or no pedal means.. what? No pressure and the pedal goes down and down and no braking happens? Or the pedal goes down, you feel resistance and push on the pedal, but very little braking happens as a result?
The check-valve on the vac line to the brake booster got 'sticky' on mine - mostly in vey cold weather. In that case, you have no vac boost assist, and the pedal is rock hard, and it takes a LOT of pedal pressure to get any braking. That braking system is NOT set up for non-assisted braking at all.
Alternatively - it sounds like in this case you have a firm pedal, but occasionally the pedal goes further down than normal, but the brakes work 'relatively' well once you get the pedal down far enough? That could be pad knock-back on the front wheels - if you have something a bit loose (usually wheel bearings) the rotor can wobble a bit while rolling and push the pads back further than they should go (they self adjust by the rotor runout pushing them back off, plus some rebound in the rubber seals). After the first push, they're more or less back to normal, second push they work normally.
JohnMc is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 03:32 PM #7
Checking the drum brakes for drag when rotating would help too. I adjusted mine recently but really didn't solve my low brake pedal. For some people it did help adjusting the drums.
Old 03-05-2021, 04:43 PM #8
Those normally get adjusted when you use the parking/hand brake. If they're a bit too loose (and the adjuster isn't stuck) then it will click a tiny increment tighter. Quote often people with automatic transmissions never use the parking brake, so they just end up getting looser and looser.
Old 03-06-2021, 11:25 AM #9
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
“Little to no brake pedal” symptom in this case means that the pedal is soft (not stiff/hard) the brakes do grab eventually, though I’m not sure I have actually experienced the intermittent issue my wife is describing.
I.e. pedal is not firm, but the opposite
Suspect MC after some research though the rotor wobble leading to caliper push-back seems worth investigating...
we use e-brake every time it’s parked, so I doubt it’s a drum adjustment issue. I think I’ve finally even trained the little lady to do this 90% of the time
Old 03-06-2021, 04:15 PM #10
You could start off by bleeding all 4 lines first and see what happens. I remember bleeding the system off mine for the first time and it got rid of all the sponge.
I would suspect a bad master cylinder if its still spongy after the job (knowing there is no air in the lines) and if it doesn't hold pressure.
Old 03-06-2021, 09:56 PM #11
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Clamp off all three brake hoses with needle nose vise grips or something equivalent and see how the pedal feels with engine running. Rock hard pedal means problem is at the wheels, spongey pedal means master cylinder or hydraulic leak.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 09:26 PM #12
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Ordered an MC and TBU goodies... will try this before digging in. Pulling and rebooting the cv’s and doing the ubj’s cuz, rabbit holes! Gotta put that diy labor savings to good use!!!
Old 03-08-2021, 10:59 PM #13
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
you symptoms resembles bladly bleeded brake lines.
Often have to bleed long and go through much oil to get all the air out. I use a transparent tube at the brake's bleeder nipple to monitor until there is NO air bubble getting out. Start with farter away brake from the brake booster.
Like I said, might take longer than you think to take all that air out, but still, this is the easiest way out to begin with.
Also worth looking if your rear brakes grabs when applying the handbrake.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
brake , intermittent , pedal , today , weak
'99 4 cylinder, intermittent stumbling and weak power. triangles 3rd gen T4Rs 19 04-11-2020 09:05 PM
Intermittent brake pedal issue Kyngfish 3rd gen T4Rs 6 03-20-2019 08:51 PM
manual transmission - intermittent soft clutch pedal hiker2 3rd gen T4Rs 12 07-22-2018 07:54 PM
E-Brake weak link SV_Dude Classic T4Rs 10 06-01-2014 05:02 PM
Weak Brake Pedal asmtrd 4th Gen T4Rs 5 08-05-2011 11:46 PM
