Old 03-05-2021, 01:29 PM #1
1aimpire's Avatar
1aimpire 1aimpire is offline
1aimpire is on a distinguished road
1aimpire's Avatar
King piggy sway rub
Just installed these brand new kings & been driving on them for 2 months. Just spoke to tech service & they dont have/make a piggy relocation bracket. What have any of you 3rd gen owners done to resolve this rubbing on the rear swaybar?
Sent from my SM-G950U using Tapatalk
1aimpire is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 02:45 PM #2
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Hey, I think I may be able to help here.
I run Bilstein 5160 piggyback reservoir shocks, which are constructed similar to these Kings. I ran into the same issue.
I ended up getting a piece of stock aluminum from my local Lowe's and made my own remote brackets, sandwiched between the bumpstop and frame like so (Swaybar was removed in these pics):
No more sway contact, and out of the way from the tires too.
Aluminum: https://www.lowes.com/pd/Hillman-3-f...-Solid/3053609
The aluminum is lightweight and pliable enough to bend without much heat. Still super rigid too. May give you some ideas. Long story short, I think I've learned that there is no way to run a sway bar out back with a piggyback resi attached to the shock.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 03:42 PM #3
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
so. clean.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 04:47 PM #4
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
@WeakSauz
Do you even drive that thing outside?! How is there not even a speck of dirt on it lol!?
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 04:52 PM #5
Originally Posted by JWaldz View Post
@WeakSauz
haha! I'm OCD and had just finished an axle swap. While the axle was out I spent 3 wks sanding and painting everything.
In hindsight, probably a waste of time since it'll just get dirty again
Old 03-05-2021, 10:33 PM #6
1aimpire's Avatar
1aimpire's Avatar
Originally Posted by cl4Rk View Post
so. clean.
Fired Up!! Simple & Sick AF!
Old 03-05-2021, 10:46 PM #7
1aimpire's Avatar
1aimpire's Avatar
Damn, bringing the heat!! Makes so much sense. Thanks for responding with an killer idea & not having to break the bank!!
Old 03-06-2021, 11:29 AM #8
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
Well this made me wonder if I was having this issue as well. I checked and my shocks and resis look good but can tell where there was a little rubbing with my over sided lower arm. Think I will be doing the aluminum strap mount soon then. Side benefit is it will make the adjuster knobs easier to get to.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 10:30 PM #9
Cool deal. I am pretty sure what happens is the shock bodies spin a little under normal use, and this causes the piggyback to rub.
Jealous of you King folks, especially with adjusters
Old 03-07-2021, 10:48 PM #10
tx_shooter's Avatar
tx_shooter's Avatar
They are nice. I am loaded up for a trip next weekend so I spent a little time today adjusting the rear shocks to comfort. Two clicks and it rode great again.
Old 07-13-2021, 02:56 PM #11
Olvrdz Olvrdz is offline
Olvrdz is on a distinguished road
Have you found a fix for this ?
Olvrdz is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 04:38 PM #12
Does it hit on both sides or just one? You might also be able to put collars on the swaybar to keep it centered for max clearance to the shock body.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-13-2021, 08:24 PM #13
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Are you sure they're installed on the correct side? I know some people have installed them on the wrong sides and they get a lot of rubbing.
My king's don't rub under normal conditions. They slowly rotate towards the center of the vehicle and would eventually make very slight contact, so every few months or thousand miles I just grab them and rotate the reservoir away from the sway bar. Basically whenever I think about it or am already under the truck.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 09:35 PM #14
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Maybe it's the 210V springs (~4.25" of lift), maybe it's the 4th gen 5160s... I don't get any rubbing with the reservoirs facing forward. They do get a little close to the frame, but I haven't noticed any marks or binding with the considerable flexing that's gone on back there in recent months.
I had more issues with the SB links potentially hitting the lower trailing arms than anything else!
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
3rd , gen , owners , piggy , sm-g950u
King Rear Shock Rubbing on Sway Bar Beach Bum 3rd gen T4Rs 10 07-13-2021 02:41 PM
Dirt King UCA's Installed now Rubbing on Sway Bar 4RFiend 5th gen T4Rs 10 01-10-2021 10:50 PM
King? Fox? Icon? Sway-a-way?... Sakums20 3rd gen T4Rs 22 11-16-2020 09:57 PM
Icon 2.5 coilovers (parts), King 700lbs coils, Sway Away shaft and rebuild kit justinh For Sale: Suspension/Wheels/Tires 3 10-15-2015 10:23 AM
