Originally Posted by 3bears
then why use the 231 if the brake pad friction area is the same ?
Good marketing strategies? No idea to be honest. Here's the thread where you can see side by side of factory brake pads between the two:
TBU 231mm vs. 199mm Pad Size
Originally Posted by HiluxSurf SSR-G
i'm pretty sure that the pistons of the 231mm are bigger than those of the 199mm. There was a post somewhere, either here or in YT, that had a comparison of the piston size. There were some complaints of having a soft or spongy brake pedal even after several bleeds and they decided to swap with a 199mm caliper and they said that the brake pedal feel improved
Both calipers use the same rebuild kit. This guy measured both pistons when he was comparing the two calipers in hand:
https://www.toyota-4runner.org/3379444-post24.html
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
