Old 03-07-2021, 10:18 AM #1
maddss maddss is offline
Real Name: Scott
maddss is on a distinguished road
Real Name: Scott
What’s wrong w/ my 4runner part 3 Update
If you have not read my last few posts, related to this craziness. If you have not here's a quick recap. 4R would try to start on its own, no key, light and horn would randomly flash, all till the battery died. I live in Maryland and over the pass 2 week there has been snow, ice storms and rain.
This is the update part. I found a small drip of water dripping onto the inside fuse box. This was causing the problem. I dried everything and the 4R runs.
Question. Has anyone had to reseal their windshield or had to replace the gasket. Are the gasket prone to wearing out/shrinking. My 94 Land Cruiser had a similar problem.
Thanks
Scott
maddss is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 12:24 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Glad to hear you found the issue.
Regarding windshield seals, I just noticed mine peeling away driver side at the top...
-837e1eb2-2472-4350-8314-a6f45fad6473-jpeg
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 05:28 PM #3
Real Name: Scott
Real Name: Scott
Anyone have any luck resealing their windshield or replacing the gasket
Old 03-09-2021, 05:38 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Your best bet would probably be contacting a windshield repair/replacement company
Old 03-09-2021, 09:19 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
picture failed to post!
Old 03-10-2021, 10:38 AM #6
cl4Rk's Avatar
cl4Rk's Avatar
Ok let’s try that again
-3140445a-15ca-4064-961a-8fa9e41eb2bb-jpeg
@Y2K_4X4
Old 03-10-2021, 11:17 AM #7
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Nope. didn't work.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:08 PM #8
cl4Rk's Avatar
cl4Rk's Avatar
Originally Posted by Reinout View Post
Nope. didn't work.
ok i'll try on desktop
-img_3696-jpg
@Y2K_4X4
Old 03-10-2021, 01:11 PM #9
Driver's side? The most likely cause isn't the windshield, but the rubber grommet where the wiring from the engine bay comes into the cab.
Water literally POURS over that rubber boot when it rains. If it is at all out of place or has aftermarket wires run through it, it will leak right into the cab.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-10-2021, 02:57 PM #10
Real Name: Patrick
Real Name: Patrick
Still not working
causing , gasket , part , problem , update
What’s wrong w/ my 4runner part 2 maddss 3rd gen T4Rs 11 03-01-2021 06:13 PM
Is something wrong with my 4Runner? _westtexasrunner_ 5th gen T4Rs 33 02-06-2020 01:23 PM
1998 4Runner Shifter Bushing and Seat Part (Canada). Can I use 2nd Gen Part? nobb 3rd gen T4Rs 6 02-03-2013 11:11 PM
dealer said my part #s are wrong and none shows up silversx 5th gen T4Rs 4 09-19-2011 07:50 PM
5100 Install HUGE Problem/Wrong Part? aviator31 4th Gen T4Rs 7 08-20-2011 05:39 PM
