Old 03-09-2021, 10:07 PM #1
1984keen's Avatar
1984keen 1984keen is offline
Real Name: Joaquin
1984keen is on a distinguished road
1984keen's Avatar
Real Name: Joaquin
What rear springs for little to no lift
Not wanting extra height, maybe just slightly more heavy duty springs in rear. Would like to avoid sag primarily.
Can anyone suggest something that can help me out?
Thank you.
1984keen is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 09:25 AM #2
tgreenwood75's Avatar
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
Lots of options are well documented on this site. OME has a stiffer spring close to stock height. Best budget option is to pick up a used set from a different vehicle. Rear springs from a 5th gen 4runner drop right in. I have a set of front springs from a Jeep JK in the rear of my 3rd gen. I think they are slightly taller than stock but a good balance of weight capacity and ride quality for my needs.
2001 T4R 4x4 3.4L AT - Bilstein 5100s, OME Coils, Wildpeak AT3Ws, 230k miles, Rust
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 09:47 AM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
You could get a set of the slightly taller 99 model rear springs. Or for a more budget choice the moog equivalent. Should be able to find part numbers here pretty easily.
The ome 2906 will poke the rear up quite a bit if the front is staying as it is now.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 11:46 AM #4
Rallysport Rallysport is offline
Rallysport will become famous soon enough
I recently got the AC Delco equivalent of the 99 talls, supposed to hold up better than the Moog version. I drive my rig pretty lightly but so far zero sag after about 6 months.
Rallysport is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:23 PM #5
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
OEM 5th gen springs would be your best bet. 1"-2" of lift (depending on your current sag) and noticeably stiffer. Also cheap!
They are slightly bigger in diameter and will be a touch loose in the spring seats at full droop, but will work just fine.
OEM or aftermarket "99 Tall" springs will also work, but won't handle extra weight well - which may or may not work for you.
'16 Honda Odyssey
Old 03-10-2021, 02:28 PM #6
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
You could get OEM 99 rear springs + airbags and adjust them in accordance to your load at the time
2000 SR5 4x4, Auto | Millennium Silver and Moon Mist | Geared and Locked | Jeep JK springs, Bilstiens/ BTF Fab | Shrockworks skids | Onboard Air | Manual Hubs | Alpine Audio
WeakSauz is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 06:17 PM #7
That's a good idea if you are going to have a highly variable load (regularly towing, for example).
'16 Honda Odyssey
Old 03-11-2021, 10:38 AM #8
Dwight_Stevens Dwight_Stevens is offline
Dwight_Stevens is on a distinguished road
Air bags will likely be the best idea for you. Easy to tune and no ride quality change.
Sent from my moto g power using Tapatalk
Dwight_Stevens is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 08:56 PM #9
shadow247 shadow247 is offline
shadow247 has a spectacular aura about shadow247 has a spectacular aura about
I'm running the 5th Gen springs on the Rear of my 3rd Gen. They work great, and I was definitely maxing flex this weekend with no issues!
2001 LIMITED 4X4 - Fresh as a Daisy at 196k! - Bone stock and staying that way! (not likely)
99 SR5 Sport - 387k and rolling! Front - Toytec 3/4 Spacer/Tundra Shocks. Rear - Daystar 1.5" Spacer/LC Shocks - GONE
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:59 PM #10
They are fine when flexing, just loose at max droop (jumping or putting on a lift). I run 10mm trim packers with mine for a touch of extra lift and to keep them snug at full droop.
'16 Honda Odyssey
anytime , avoid , primarily , sag , springs
Refreshing my 10 year old lift kit audiness 3rd gen T4Rs 3 12-16-2020 09:50 PM
Sold: FS - Dobinson C59-675V Rear Springs - 3 inch lift springs - Denver - $175 Spudgey For Sale: Suspension/Wheels/Tires 1 07-21-2020 06:12 PM
18 year old springs and shocks...toss em? benjamin247 3rd gen T4Rs 10 03-10-2015 01:16 AM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
