Old 03-10-2021, 02:10 AM #1
Philbo Philbo is offline
Philbo is on a distinguished road
Engine hesitation ***Need help***
Hi everyone,
So I performed a 5 speed swap on my 1999 3.4l. It went fine and the truck ran great for at least a week with the auto ECU. Then I figured the immobiliser on my manual ECU and swapped this one. The truck ran fine for another couple of days then starts to hesitate @ low rev and more than 1/3 of throttle. Runs pretty smooth over 2000rpm. I reswapped the automatic ECU and no luck, stays the same so I dont think the ECU is related.
-I changed my MAF and my TPS with no success.
-I look for a vaccum leak (visual and with propane), no luck.
-No CEL in the dash. If I check the pending codes I have #5missfire (not surprise since the truck jerks at every take off.
-Seems to be running a little smoother when cold
Not sure what to look for now to avoid changing every sensor of the car.
Any path to follow or ideas?
Thanks in advance folks!
Phil
Philbo is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 09:29 AM #2
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
If you're getting a code for a misfire on Cyl5, I would start by pulling that plug, check the plug, coil, wire. Could just be something up with only that cylinder that feels like it smooths out at higher rpms because the other cylinders can keep up? Perhaps when colder it idles higher so it is less noticeable if you feel it more at lower rpm?
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 07:20 PM #3
ocbruin ocbruin is offline
ocbruin is on a distinguished road
Scotty on youtube has a great diagnostic for misfires. You should be able to swap the coils, read the code and see the misfire "move" if that is really the problem.
ocbruin is offline   Reply With QuoteReply With Quote
ecu , fine , luck , ran , truck
Engine Hesitation/ Stumble ADVnut 5th gen T4Rs 40 10-09-2022 02:15 AM
engine whine and shift hesitation Riders of Lohan 3rd gen T4Rs 7 05-16-2014 02:29 PM
Throttle Hesitation Only When Engine Light is OFF 97ls340 3rd gen T4Rs 10 11-21-2013 06:28 PM
Engine hesitation Tony45525 General Discussions 2 04-09-2010 04:42 PM
HELP! Check engine light, hesitation.... ACK! dman328 3rd gen T4Rs 2 08-16-2006 06:29 PM
