Old 03-14-2021, 07:13 PM #1
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Sudden, random, no-start (Immobilizer issue suspected)
This is annoying, I've somehow managed to make my 4R a non-starter while fussing with the seats. By non-start, I mean that it cranks as normal but won't "catch". That's today, yesterday it was sorta catching and running Terribly, let it sit for ~30 minutes and then it started up and ran fine, same with this morning (started right up and ran fine first time).
I only just noticed that my security light continues flashing with all 3 keys, I'm pretty sure at least 1 of those is a Master (light should go out immediately), which is why I suspect the IMMO system.
Work I've been doing is finally getting around to wiring up the heated seats for my wife and dropping the rear mounts on the drives side to give myself some more headroom. Seats in and out a few times, disconnected the ground terminal from the battery while connecting the hot lead ~ nothing I haven't done a hundred times before. Today I pulled the fusebox to look at finding a place for a trigger wire for the seat heaters relay (only want them on when the vehicle is key-on). I decided to just do the add-a-tap via a switched fuse, so I didn't do anything to the wiring beyond nosing around.
I'm beyond frustrated right now, so I left it on a battery charger (was a little low). I happen to have a spare body ecu with key that's programmed to the immobilizer, so I plan on swapping that in tomorrow though I honestly don't believe this will resolve the problem. I'm also posting this before searching, but my first search is going to be tracking down the wiring/connectors for the immobilizer system from the ignition on back. It really Feels to me like there's just a bad connection.
Thing is, I'm a motorcycle mechanic (and old cars... like, points and carbs era), so I don't know enough to even search effectively. Anything else I'm missing to this system? It's just a pickup at the ignition and the ECU that processes that info, right?
Another oddity, Torque is having a hard time connecting to the OBDII reader (I've used this same device without issue for a couple years, just used it on another vehicle a few days ago). I haven't tried techstream yet, mostly because when I managed to get Torque connected, it showed zero faults. Leads me back to thinking it's something wonky in the Immobilizer system.
Thoughts?
Brian. is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 03:19 PM #2
Brian.'s Avatar
Brian.'s Avatar
99% sure I've found the problem today...
But first, my dumb self somehow managed to not tape my old key (loop was eaten off by the PO's dog, probably went through the dogs gut at some point) to the top of my spare ECU ~ couldn't find it Anywhere ~ so I couldn't test that. Then, while pulling the chip to re-virgin it, I burned off 2 of the pads that go to the traces..... to be fair, I *might* have burned those off initially when "testing".
Today I pulled the one that was in the truck and working fine for the past ~14 months. Used my new hot-air rework station (OMG! Talk about the RIGHT tool for the job!) to practice a little on the now-trashed ECU before pulling the IMMO chip. Pull the IMMO chip only to see that 1 trace came off with the chip. You ever get that "sinking" feeling, where your heart just drops a little? Yeah, well... I felt that. Then felt some other things when I told the wife....
So, I'm guessing that my lack of skills and trying to use the wrong tool to do the job, lead to an early failure... and one that no one else is likely to experience (except those who try to follow my path of making a master key).
What I now need is a new ECU. Help guys? Yup, I'll post in the classifieds too..
89661-3D570
I'm a pre 05/May 1999 (apparently there's a change there), V6, 4x4, AT
Cheers!
Old 03-18-2021, 03:25 PM #3
spartacus's Avatar
spartacus's Avatar
89661-3D570
Cheers!
I just Googled it. not bad for the price
https://rover.ebay.com/rover/0/0/0?m...Fp%2F657541270
fine , immobilizer , ran , seats , system
Sudden, random electrical death? Greaser 3rd gen T4Rs 20 06-12-2021 01:45 PM
Sudden Fuel Tank issue, can't refill without trouble jross20 3rd gen T4Rs 20 05-19-2021 08:15 AM
Engine immobilizer 2010 T4R - no start inrebuttal2u 5th gen T4Rs 12 09-07-2020 02:12 PM
No Power, No Start (very sudden, w/ good battery) timmytimtim 3rd gen T4Rs 11 12-15-2019 01:51 AM
2007 2WD SR5 won't start no crank; any way to bypass the immobilizer system VolcanoT4R 4th Gen T4Rs 4 01-29-2015 07:33 PM
