03-14-2021, 08:53 PM
Synthetic/conventional mix
I just did an oil change and realized I accidentally put a 2 qts. of conventional oil in with my synthetic oil. I’m well aware of how stupid that was but I was rushing and had an extra 2 qts. laying around and I didn’t realize until I was done. Anyone know if it’s gonna be an issue? I’ve asked a couple sources:
My dad said that it used to be an issue but he doesn’t think it is anymore.
My uncle said the same thing, and my cousin called me an idiot.
I spent some time on Google, which said that it used to be an issue but isn’t anymore. I’m not sure if this means that oils have changed, or if this only applies to new cars…
Obviously I’d really like to not do another oil change, but I will if its an issue. I’m going down to Mojave this weekend so I want to make sure I’m in good condition.
I have 18 miles on the oil change.
Thanks
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
03-14-2021, 09:04 PM
Thanks
If both oils were the same weight, I dought it will effect performance.
03-14-2021, 09:15 PM
Yeah, they're both 10w-30. Thanks!
03-14-2021, 09:39 PM
Real Name: Ron
Real Name: Ron
No problem, now you have a synthetic blend instead of full synthetic. Run it till next change and then pay more attention.
03-14-2021, 09:48 PM
Real Name: Ed
Real Name: Ed
You'll be ok.
03-14-2021, 09:52 PM
No cause for concern.
03-14-2021, 10:40 PM
No issue. Honestly I'm not convinced there is any 100% synthetic. They all use conventional to some extent and synthesize the rest. So you got a blend and even full synthetic are technically blends to a degree. With that said I'm a fan of conventional for our motors given the era they were made unless you've modified for forced induction synthetic not necessarily needed and due to its thinner finer particles you may see leaks using synthetic sooner then if thicker conventional oil were uses. Sure you can get by using synthetic longer for more miles. But most of us here are current and keep current on routine fluid changes and check so conventional is my preferred
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
03-14-2021, 11:12 PM
Originally Posted by G_Raw
No issue.
Originally Posted by Ed_C
You'll be ok.
Originally Posted by rdruss
No problem.
Thanks guys!
03-14-2021, 11:33 PM
Real Name: Jerod
Real Name: Jerod
Seeing how forgiving these engines are, one could run ATF in the engine and it'll still truck on.
Please don't try it though.
03-15-2021, 04:05 AM
I actually ran a qt in my old 96 Saturn to try and help uncoke the oil rings. It would use a qt every 1000 miles.
03-15-2021, 09:52 AM
Real Name: Patrick
Real Name: Patrick
Works pretty good at gently cleaning sludge deposits too. A little more aggressive than regular oil, but way more gentle than an engine flush additive etc.
03-15-2021, 10:57 AM
Did it help? The 7afe in my corolla has a bit of an oil drinking problem too. Known to foul the rings.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
03-15-2021, 12:12 PM
I used the ATF as a make up oil sometimes also. It helped. I eventually halved my oil consumption it 1/2qt per 1000 miles.
Diesel oil works good also. 5w30 Rotella T5.
BJ109 engine flush is another great product.
I did the ATF, Diesel oil, and the BG109. Over time I got it to 1/2qt per 1000.
03-15-2021, 12:36 PM
Real Name: 3 Bears
Real Name: 3 Bears
as far as the OP.....you will be fine.
off main topic but fits with above posts....
on the ATF in oil talk....at a shop I used to work at, we would occasionally flush an engine with ATF to unstick rings etc. On really bad ones, we would put atf directly into the cylinders and let it soak a day or two, spin it with plugs out to get rid of it. If doing a head gasket job, we would pull the heads, scrape off piston tops and then put atf in the cylinders and let soak while heads were off.
this is just what the old man and owner of shop had us do. so we did ( yes boss). I did see it unfreeze a tractor motor that had filled with water in the cyliders and sat for a year. ( that was a 50/50 mix of atf and acetone...sat for a few days and then it would spin,...pumped stuff out and started) The old guy swore by that mix.
If this new to me rig had not passed a compression check, i would have tried atf in the cylinders and let soak.
try at your own risk
03-16-2021, 10:35 AM
Real Name: Patrick
Real Name: Patrick
I've used the 50/50 trans fluid/acetone as a penetrating oil. It works pretty good too.
