Old 03-18-2021, 07:40 PM #16
patrickdotryan patrickdotryan is offline
patrickdotryan is on a distinguished road
thanks phattyduck, that is really helpful info.
Yes, she does use the park brake, although in testing we left the car operational for a week without using the park brake and the issue still occurred and we also spun the back wheels freely, so we ruled that out.
But I really like the advice that it may be way out of whack. Rear brakes are easy and cheap to fix, so I'd love it to be that! More so than an ABS system!
Really appreciate yours and everybody's help and I will come back here to post any results.
Cheers,
Patrick
My daughter’s 1998 4Runner Limited
160,000 miles
California truck, clean, no rust, no salt roads.
2WD
patrickdotryan is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 09:25 PM #17
slayman slayman is offline
slayman is on a distinguished road
Also have a 99 Highlander. Replaced rotors this past weekend. There's a thread on page 4 or so with "Power stop" in the heading if you're interested. Here's my summary:
Follow up: I did not do the TBU. Why, well, I don't tow much other than an aluminum trailer with yard stuff and perhaps a motorcycle, this is a first time project for me and I didn't feel like getting into caliper replacement. So, I bought an EBC kit from Auto Zone. GD rotors and Greenstuff pads. Installed yesterday with most of the work being done by our do everything shop guy at work. I am glad I had the assistance of an experienced mechanic when it came to the best methods for removing caliper bolts etc. without screwing something up. While the tasks are pretty straightforward his experience made the job much easier. So if I remember, I'll post an update once the brakes have some miles on them.
EBC parts: pads green stuff DP6807 , rotors GD7236. so far so good feels way better than the wheel shaking old rotors. One reason I picked the EBC parts is I've had good success with them on my motorcycle.
slayman is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 09:53 PM #18
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Bonus question, if it does not, then sounds like an ABS pump problem, I see those are No Longer Available, does anyone rebuild those?
I think the units are rebuildable. This does sound like a gamble but since you mentioned there is a leakage, I would replace the components with ABS so you can still keep the ABS on the truck. Worst comes to worst, the ABS or something else comes out to be the problem.
2000 4Runner Limited 4x4 V6
Old 03-26-2021, 05:07 PM #19
Hi all, checking back in. For reminder, my daughter's truck had brake sticking issues after being parked. Rotors (warped) and pads were due for replacement and also our Toyota indy said calipers were sticking, so replaced those too.
This didn't fix the sticking issue so to trouble shoot, I pulled the ABS fuse to see if that was a problem and also tested the wheel sensors. That didn't solve it. Additionally, without the ABS fuse, the (new) brakes shuddered just before the truck came to a stop. Felt like ABS pump activating while powered down. We assumed this would go away when fuse was put back in.
So on the second visit, Toyota indy suggested to fix the still-occurring brake sticking issue, we replace the leaking master cylinder, which was pooling fluid into the booster. We replaced both.
Seems the booster / MC issue has solved the brake stick issue. However, even though the ABS fuse is back in, the truck still does the "shudder" when coming to a slow stop. Even if conditions are dry etc.
is there any way that the ABS can be reset or something? This was not happening before we pulled the fuse. Effectively we just powered it down and drove it, much like all the people who have a switch to turn off ABS when they're off-roading. In fact I got that from this forum.
Any thoughts on how to resolve? Seems like te brake sticking issue is fixed, but now it is super annoying to drive around town.
Thanks
Patrick
160,000 miles
2WD
Old 03-26-2021, 05:50 PM #20
spartacus's Avatar
spartacus's Avatar
When the brakes were draging they may have left flat spots on the rotor. Get the rotors turned and new pads.
Old 03-26-2021, 06:52 PM #21
Thanks Spartacus, that is a great suggestion. Unfortunately, he replaced pads and rotors first. When that didn't fix the issue he replaced the m/c and booster and I made him replace the pads and rotors again under warranty, which he did. So, brand new is calipers, pads, rotors, master cylinder and booster.
Cheers,
Patrick
160,000 miles
2WD
Old 03-26-2021, 07:21 PM #22
spartacus's Avatar
spartacus's Avatar
Cheers,
Patrick
Gotchya. You can bed the brakes and see if it helps.
Old 03-28-2021, 01:06 PM #23
RedOneTheCrafty RedOneTheCrafty is offline
RedOneTheCrafty is on a distinguished road
Tundra Brake Upgrade For 3rd Gen 4Runners
Originally Posted by airdreams1 View Post
I have a 99 4Runner SR5 Highlander SP. From what I can understand it has larger brake calipers and rotors than a standard SR5 and limited. Yes I need to replace the rotors because I have one that is Warped. Maybe need drums too.. I'm not sure yet. Anyway Does anyone know if there is something special I'm supposed to use or if there's an aftermarket something that fits that I don't have to buy from Toyota directly? Yeah I know sometimes the dealership sells the best parts but four front and rear brakes rotors drums pads what's going to be somewhere near $1,000 from my local Toyota dealer and that's if I install them myself.
eventually I'll be needing to do shocks and struts & will probably need that kind of information.... can't really afford to pay $500 per corner from the dealership on this vehicle.
yes lower ball joints are on my list of things to do in the very near future. Unfortunately those will definitely have to be Toyota. I understand that every other option is basically trash that will not last. Having a lower ball joint failure is not something I want to take a chance on.
Any information/help would be greatly appreciated.
I have seen a lot of youtube videos and everyone does a tundra brake upgrade,they fit and won't ever warp
RedOneTheCrafty is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 01:11 PM #24
https://www.youtube.com/watch?v=ZbsilXq23uo&feature=youtu.be
Old 03-29-2021, 09:12 AM #25
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Does the steering wheel shake of vibrate when braking? Does your vehicle vibrate if you pull the parking brake while driving?
ball , joints , sr5 , toyota , understand
Time to do the brakes..Which pads? wsudu 4th Gen T4Rs 16 02-14-2024 03:28 PM
Time for brakes, 04 Sport 4.7 TankTop 4th Gen T4Rs 1 03-16-2015 11:04 PM
Time for new Brakes. What are ya running & where did ya get them? Bftfan 4th Gen T4Rs 10 10-02-2011 05:54 PM
Time for brakes. mole177 General Discussions 12 07-09-2010 07:20 AM
Something up with brakes or just time to replace? Jeremy03Sport Problems & Warranty Issues 6 01-26-2006 07:28 PM
