Old 03-15-2021, 11:08 AM #1
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Front suspension travel
Anybody have any ideas on the most you can get out of our front suspension without going to long travel? I guess what I’m asking what the max suspension travel is out of the front. I don’t really want to mess with going long travel because I don’t want to run spacers in the rear or have to get fiberglass fenders or any of that jazz. I’ve read that JBA uca’s give you more travel is there any equivalent in the lower control arms that would give us more travel and that maybe has a better lbj design? Or is there no real difference in anything we could change without going wider because the cv axle maxes out travel? Just lookin for some info/opinions
TW44LR is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 11:14 AM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
According to eimkeith: why Body Lift? – eimkeith.com
so basically, a 2” suspension lift and a 1” (1.25” in my situation) body lift nets more suspension travel and lower COG than that of a 3” suspension lift, with the break-over clearance of a `4” suspension lift.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 12:41 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
So this overrides/takes into account shock compressed length vs. extended length vs. installed length and coil bind of the spring? I assume those would have some effect on suspension travel.
Old 03-15-2021, 01:56 PM #4
The search for max travel with stock length arms is "mid-travel" in the terms used here. Get to searching!
Options include:
- body lift and bump stop modifications for increase up travel
- upper arms for increased droop travel
You'll end up limited by the CV joint articulation limits and shock travel.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-16-2021, 02:38 PM #5
TW44LR's Avatar
TW44LR's Avatar
Thanks for the replies all, I’ll look into mid-travel since. I had heard of that but wasn’t sure exactly what it meant. I have a 1” body lift already and am a big fan of @work and products. As money permits I’ll hopefully have all of his goodies haha. Just brainstorming on what I want to do next for the front end. Good to know and confirm that the cv axles will end up limiting travel in the end but with the 1” BL and some modifications to the bump stops I should be able to get some decent travel.
Old 03-16-2021, 02:41 PM #6
TW44LR's Avatar
TW44LR's Avatar
Options include:
So is there any LCA’s that would be beneficial in the situation I’m looking for? If not I assume best would be just to build up the oem with new bushings and eimkeith’s reinforcements
Old 03-16-2021, 02:46 PM #7
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
Tacoma front sway bar
You could also look at using the 2004 Tacoma front sway bar. It allows for more drop. I think it's installed on the TRD models only.
I'm considering this upgrade.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 02:57 PM #8
cl4Rk's Avatar
cl4Rk's Avatar
Not sure if it’s helpful to you or not, but check out DuroBumps 5.25” bump stops set.
@Y2K_4X4
Old 03-16-2021, 03:14 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sway bar does not limit down travel but limits the amount that left and right can be at different heights. For best front flex disconnecting the sway bar is recommended.
Old 03-16-2021, 05:22 PM #10
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If you do, use Super Pro or Whiteline bushings. Either will provide free movement of the LCA as opposed to the OEM which lock the LCA in place and movement is by twisting the rubber.
Old 03-16-2021, 10:56 PM #11
TW44LR's Avatar
TW44LR's Avatar
I’ve got white lines currently just didn’t put them on because I haven’t taken the LCA’s off yet. Figured at the same time I’d do the reinforcements.
Old 03-16-2021, 11:00 PM #12
TW44LR's Avatar
TW44LR's Avatar
I’ll keep the regular one on for now. I’m planning on taking it off permanently whenever I get coilovers with valving adjusters. Had it off for a while and the ride was softer will definitely keep it off when I could adjust the stiffness on the actual shocks.
Old 03-16-2021, 11:01 PM #13
TW44LR's Avatar
TW44LR's Avatar
Will do I’ve only heard good things. Have also heard hyrdo bumps are awesome so I might just take the jump to their when it gets to that point.
Old 03-17-2021, 12:33 AM #14
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Fwiw this is something I've been wondering for a while and can't seem to get an answer on. Everyone says "just replace the bushings" but with how much of a pain it is to get the arms out AND the bushings too, you might as well just swap it out for a new set if you find your time valuable. Which sucks because theres definitely some options available, just nobody with any experiences on them. If you come across something I'd be interested in seeing it
If you were curious, in regards to UCAs, JBA offers a very nice pair for our vehicles that net another +1in of droop, with zerk fittings on both the ball joint and bushings too. Supposedly make highway driving a dream, too. Can't wait to put mine on
Old 03-17-2021, 10:49 PM #15
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
dunno if this helps:
1st Gen Tacoma & 3rd Gen 4Runner Lower Control Arm Kit - Stock Length | Solo Motorsports
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
don’t , front , give , suspension , travel
99 suspension travel vs other 3rd gen years yotadawgjr 3rd gen T4Rs 2 02-28-2018 06:17 PM
Suspension Travel Sisente All Other Vehicles 1 09-18-2017 01:07 PM
Too much suspension travel BackOff 4th Gen T4Rs 9 03-22-2016 09:58 PM
Sas vs long travel suspension! B.peat Classic T4Rs 14 09-03-2013 05:36 PM
Question about suspension up-travel DRC Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-23-2010 09:50 PM
