Old 03-15-2021, 08:10 PM #1
Lord Revan Lord Revan is offline
Lord Revan is on a distinguished road
Fuel gauge/pump/tank issue
My 4Runner just left me stranded on the interstate...
2001, Limited, v6, 4wd, 151k miles
6 months ago, I was driving home and the 4Runner stuttered and died. I looked at the gauge and saw the fuel gauge was reading empty. I thought it was super strange since I've never run out of gas before and isn't the type of thing I'd overlook. Bought a gas canister, added 1 gal, drove it home. The next morning when I turned the key, the gauge read 1/4 full. I was a little confused but continued with life.
Occasionally while filling up at the gas station, the gas pump shuts off prematurely. I know the tank isn't full, so I wait 30 seconds and add some more. This has happened a few times.
TODAY
Drove to the gym, parked, and saw that the gauge was reading almost empty with the fuel light on. Same deal as before, I could have sworn I had 1/4 of a tank when I left. Start the car after working out and, sure enough, it reads 1/4 full.
I start to drive home on the interstate while keeping an eye on the gauge since I think there might be a problem. It starts dropping waaaayyy too fast, stutters, and dies. I give it some time to see if the gauge will pop back up. It doesn't, so I call a friend and do the gas thing. After adding 7 gallons (even though I know it has gas) the gauge still reads empty and it won't run longer than 20 seconds before dying.
Can someone please explain this to me? I'm not sure where to start troubleshooting. I know the truck has gas but it keeps dying like it has run out of gas. Do these trucks have some kind of safety system where the pump shuts off if the gauge falsely reads empty?
I'm considering ordering a new fuel pump assembly, but after doing a little research online it seems like there are other common issues with the fuel system that are typically the issue with incorrect gauges, i.e. the ground wire for the sending unit.
Any help would be greatly appreciated. My baby is just sitting on the side of the interstate right now...
Lord Revan is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 10:37 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
TODAY
There's not a safety system or shut off system if the fuel gauge doesn't read any fuel in the tank. It sounds to me like the fuel pump is your culprit.
Old 03-16-2021, 12:56 PM #3
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Try replacing the gas cap first of all. There is a pre-filter in the tank that can get clogged up as sediment swishes around on inclines or whatever. There's also some sort of baffle thing in there which causes trouble but was supposed to be fixed after 2000 when they redesigned the sending unit. You can easily test the vapor pressure sensor and fuel pump from the access hole under the rear seat to rule that out.
1.INSPECT POWER SOURCE VOLTAGE OF VAPOR PRESSURE SENSOR
(a)Disconnect the vapor pressure sensor connector.
(b)Turn the ignition switch ON.
(c)Using a voltmeter, measure the voltage between connector terminals VC and E2 of the wiring harness side.Voltage: 4.5 - 5.5 V
(d)Turn the ignition switch OFF.(e)Reconnect the vapor pressure sensor connector.
2.INSPECT POWER OUTPUT OF VAPOR PRESSURE SENSOR
(a)Turn the ignition switch ON.
(b)Remove the fuel tank cap.
(c)Connect a voltmeter to terminals PTNK and E2, and mea-sure the output voltage.Voltage: 3.0 - 3.6 V
(d)Reinstall the fuel tank cap
INSPECT FUEL PUMP RESISTANCE
(a)Pull up the LH rear seat cushion.
(b)Remove the floor service hole cover with the 3 screws.
(c)Disconnect the fuel pump connector.(d)Using an ohmmeter, measure the resistance between ter-minals 4 and 5.Resistance: 0.2 - 0.3 Ω at 20∞C (68∞F)If the resistance is not specified, replace the fuel pump and/orset plate.
INSPECT FUEL PUMP OPERATION
(a)Connect the positive (+) lead from the battery to terminal4 of the connector, and the negative (-) lead to terminal5. Check that the fuel pump operations.NOTICE:These tests must be done quickly (within 10 seconds)to prevent the coil from burning out.Keep the fuel pump as far away from the battery aspossible.Always do switching at the battery side.If operation is as not specified, replace the fuel pump and/or setplate.
(b)Connect the fuel pump connector.
(c)Install the floor service hole cover with the 3 screws.
(d)Connect the LH rear seat cushion
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 01:26 PM #4
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
If its the orIginal fuel pump just replace it with a denso unit also the gaskets.
Old 03-16-2021, 02:05 PM #5
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Replaced the PUMP and the Fuel sending unit. There was a service bulletin years ago that said it could cause erratic fuel readings on the 99-00 I believe.
The only irritating thing is you have to drop the actual tank to do it, rather than getting at it from the rear seats, but I just made sure it was somewhat empty and use a jack to support it as I lowered it.
I did mine proactively about 10 years ago, even though it didn't display these issues. It's been solid since then.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 03:55 PM #6
Thanks a ton for the info and suggestions! Looks like replacing the pump is in my future. Even if I can't track down an error with a meter, it's probably a good idea.
UPDATE
I checked on the car this morning and as soon as I turned the key, the guage read about 1/3 full, so I left my Tacoma on the side of the interstate and drove the 4Runner home. So now I can troubleshoot the problem in the garage instead of on the side of the road.
empty , fuel , gas , gauge , pump
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
Gas Pump Shutting Off / Can't Fill Fuel Tank? Jeremy556 5th gen T4Rs 19 07-11-2023 09:18 PM
Fuel tank or Fuel pump problem? TwoToneT4R 3rd gen T4Rs 6 11-30-2017 04:18 PM
Gas leak around fuel pump on top of gas tank TeamUSA 3rd gen T4Rs 5 07-09-2015 08:51 AM
Fuel Gauge and tank size Paradise87 Classic T4Rs 6 04-19-2012 09:28 PM
