Old 03-17-2021, 04:53 PM #1
blue1 blue1 is offline
blue1 is on a distinguished road
Front crank seal
Does Toyota make a front crank seal that is thinner (so the seal doesn't ride in the old groove)? If so does anyone have a part # for it? I really don't want to use a Speedi sleeve
blue1 is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 08:32 PM #2
nissanh nissanh is offline
How bad is the grove?
I heard a trick where they tighten the inner spring inside the O-ring to make the lip tighter. How about not driving the seal all the way in? By the way, toyota seals lasts a very long time. My LC at 238K mies and got OEM seal.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 03-17-2021, 08:44 PM #3
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Why not use a sleeve ?
Balancers are 100 ~ 300 $$
SaulG is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 11:12 PM #4
fullmoonguru fullmoonguru is offline
fullmoonguru is on a distinguished road
+1 for driving the seal in a little less or more. Only a small amount should work.
fullmoonguru is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 02:52 AM #5
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
+2 for relocating seal, don't drive it all the way home, maybe use sealant on the outer surface for good luck, the next person in there will hate you though.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 08:38 AM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Have never run into this problem with Asian cars, even when previous idiots have gone crazy using screwdrivers to remove the old one. The right amount of grease and setting it correctly has worked every time for me.
Now on American engines, such as the 350, a sleeve is almost mandatory if the dampener isn’t replaced.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 09:11 AM #7
When I did the timing belt on the 96 the Toyota crank seal pushed in the oil pump with my thumbs way too easy. I put a napa seal in instead. It went in tight and set properly.
crank , front , part , seal , speedi
Crank Shaft Seal? golfinw71 4th Gen T4Rs 7 04-15-2017 09:39 AM
Crank Seal DIY: LittleCaesar 3rd gen T4Rs 0 10-28-2014 05:09 PM
V6 Crank Seal Leak Synister 4th Gen T4Rs 1 03-23-2013 03:37 PM
crank seal capo Classic T4Rs 0 10-30-2008 09:40 PM
22R series front crank seal repair Sidney Classic T4Rs 0 01-26-2008 08:23 PM
