Closed Thread
Old 03-18-2021, 02:20 PM #1
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
Marlin HD clutch out of stock
I need to replace my clutch and I want to use the Marlin HD but it's out of stock for a few weeks.
I would like to have gotten it directly from Marlin but I'm in a time crunch to get my Runner back on the road.
Does anyone know the Seco and Aisin part numbers for the components?
I'm interested in the 1200# HD clutch for the 3.4l V6.
Thanks,
'02 SR5 1st gen supercharged, urd 7th injector, 2.2 pulley, tru trac, fab tech coil over 3" lift, manual hub conversion, 5speed conversion with multi mode transfer case.
Old 03-20-2021, 06:19 PM #2
photoleif photoleif is online now
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
captured these from when i put a marlin clutch set in mine.
cover assembly: aisin CTX-107
clutch disc: SECO SDTY-136/CD80101
throwout bearing: nachi 61462 (or CB 56017 or NP-50SCRN60P-2-P)
pilot bearing: nachi 62012NSE9C3 (or 190211)
'99 'Highlander' 4R SR5 5VZ-FE | Manual transmission | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
Old 03-20-2021, 06:43 PM #3
Awesome thanks! I'm going to try and find those parts now.
Old 03-21-2021, 08:14 PM #4
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan is on a distinguished road
Post back if you find anything!
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
'98 Limited V6 4x4 | automatic | e-locker
Old 03-22-2021, 02:03 PM #5
Marlin is back in stock, so I just ordered one.
I could find the pressure plate in stock but the clutch with the part number listed above either is incorrect or is a special order. It doesn't exist in any catalog I could find.
Thanks,
Old 03-22-2021, 04:41 PM #6
Real Name: Leif
Real Name: Leif
Thanks,
sorry if it ended up being a bit of a chase. i pulled the PNs off the item packaging from the kit that marlincrawler sent me.
Old 03-22-2021, 08:17 PM #7
SaulG's Avatar
SaulG SaulG is offline
SaulG is on a distinguished road
SaulG's Avatar
SDTY -136 . . 31250-35310 suprcds to 31250-35400; 31250-35400-84 . .
32150-34010 and -37060 as well as -37160 = which are T-100 ~Hi Ace ~Prado ~Surf even 4.1 L diesel? ? ?
SDTY -346 . . is reg 3.4 Tundra Taco 4runner T-100
maybe anniesball72 can enlighten us when he receives his ?
SaulG is offline
Old 03-25-2021, 06:53 PM #8
So what I got from Marlin was the following SECO parts. The Aisin pressure plate is still not available.
SDTY-136/CD80101 disc
SCTY-383/CA70165 pressure plate
So from reviewing your post with all the part numbers it appears it's a stock clutch now if I'm not mistaken????
Old 03-26-2021, 04:30 PM #9
For the disc SDTY-136 you list a bunch of part numbers that are superseded and then you state the SDTY-346 is reg. 3.4 ...... So is the SDTY a heavy duty clutch, metallic?....
Thanks,
Old 04-01-2021, 09:01 PM #10
SaulG's Avatar
SaulG's Avatar
SDTY-136 looks to be "heavier" of the two .. 346 is listed as "stock"
SCTY-383 95-04 Taco 3.4l
quickest is
SECO2017CATALOG
CD80101 CA70165 are APRA numbers..
SaulG is offline
Closed Thread
clutch , components , marlin , road , stock
Marlin Crawler HD clutch nightmare yotadawgjr 3rd gen T4Rs 5 08-31-2017 03:44 PM
FS Marlin Crawler HD Clutch kit for 3.4 TX PhdNPrerunners For Sale: T4R Items 2 03-24-2015 08:16 PM
Marlin Clutch.. Which one? austinjt Classic T4Rs 1 11-23-2010 05:51 PM
Marlin Crawler SHD Clutch mspa Classic T4Rs 1 10-18-2007 04:58 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
