Old 03-18-2021, 04:06 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough
Want to Upgrade to 01-02 Tail Lights
I got a passenger tail light off a 2002 4Runner from the scrapyard for $10 and love the cleaner look rather than the pre-2000 tails. Installing it to see how it looked, I discovered the reverse socket is too big to fit the 02 tail light. To rewire, can I just cut the original wire and rewire the 02 wire for the reverse light to work or do I have to do something else to make it work? Soon I will get the driver side tail light.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 03-18-2021, 04:23 PM #2
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Swap the harnesses to the '01/'02. Takes 5 minutes to access them from inside the quarter panel trim.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:38 PM #3
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
^^^ Even if you DID tap in a new connector, how would it fit in the tail light housing? The 01-02 reverse lights are a 2825 bulb instead of a 7440 and the hole they lock into is much smaller as a result.
It's a shame, I too love the clear tail lights but ultimately I made the switch back so I could have bright reverse lights.
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Devbot is online now   Reply With QuoteReply With Quote
Old 03-18-2021, 09:41 PM #4
I would've just cut the reverse light housing off another 4Runner and rewired it to mine but now knowing I can swap the entire housing, I will just do that instead.
Old 05-12-2021, 12:53 PM #5
3bears 3bears is offline
Real Name: 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
Real Name: 3 Bears
other than looks, is there an advantage to this ?
If so then maybe if I find a 99 or 2000 I will swap the tail lights from my 2001.
Sure another buyer wont notice, this 2001 is rough as it is.
2000 SR-5 Highlander. 4:30's, factory locker green
2001 SR-5...sold june 2021
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, totaled 10/20
Old 05-12-2021, 10:14 PM #6
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Purely aesthetic
Old 05-21-2021, 07:09 PM #7
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
The junkyards I went to had cut the wire harnesses. You can order the correct ones from Toyota if your yards are like here where they’re all cut
PN# 81555-35240 / 81555-35200
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 11:04 AM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
They do look Way cooler! : ^ )))
2001 Limited 4WD - 331+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
light , rewire , tail , wire , work
WTB or Trade 2012 tail lights & harnesses for 2014+ tail lights & harnesses Vaultervon33 Want to Buy/Trade 2 02-09-2017 04:43 PM
FS: 3rd Gen Tail Lights, Corner Lights, Cargo Cover, Running Boards mtravis8 For Sale: T4R Items 1 12-06-2012 03:42 PM
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
Clear Tail Lights, Tail Light Guards, & Many Bulbs For Sale! Fo_SheeZy 3rd gen T4Rs 21 09-11-2011 04:35 PM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
