Old 03-18-2021, 04:06 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough
Want to Upgrade to 01-02 Tail Lights
I got a passenger tail light off a 2002 4Runner from the scrapyard for $10 and love the cleaner look rather than the pre-2000 tails. Installing it to see how it looked, I discovered the reverse socket is too big to fit the 02 tail light. To rewire, can I just cut the original wire and rewire the 02 wire for the reverse light to work or do I have to do something else to make it work? Soon I will get the driver side tail light.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 03-18-2021, 04:23 PM #2
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Swap the harnesses to the '01/'02. Takes 5 minutes to access them from inside the quarter panel trim.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:38 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
^^^ Even if you DID tap in a new connector, how would it fit in the tail light housing? The 01-02 reverse lights are a 2825 bulb instead of a 7440 and the hole they lock into is much smaller as a result.
It's a shame, I too love the clear tail lights but ultimately I made the switch back so I could have bright reverse lights.
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / CVJ 9168R Axles / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / Braided + Extended Brake Lines / Extended Sway Bar Links / Elbow Delete + ISR / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod / 4x Innovations Front Skid
Old 03-18-2021, 09:41 PM #4
I would've just cut the reverse light housing off another 4Runner and rewired it to mine but now knowing I can swap the entire housing, I will just do that instead.
Old 05-12-2021, 12:53 PM #5
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is just really nice 3bears is just really nice 3bears is just really nice 3bears is just really nice 3bears is just really nice
other than looks, is there an advantage to this ?
If so then maybe if I find a 99 or 2000 I will swap the tail lights from my 2001.
Sure another buyer wont notice, this 2001 is rough as it is.
2001 SR-5...bone stock ( for now) bought 12/10/20. thunder cloud metallic,
gray cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20. Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
Old 05-12-2021, 10:14 PM #6
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Purely aesthetic
Old 05-21-2021, 07:09 PM #7
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
The junkyards I went to had cut the wire harnesses. You can order the correct ones from Toyota if your yards are like here where they’re all cut
PN# 81555-35240 / 81555-35200
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 11:04 AM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
They do look Way cooler! : ^ )))
2001 Limited 4WD - 331+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
light , rewire , tail , wire , work
WTB or Trade 2012 tail lights & harnesses for 2014+ tail lights & harnesses Vaultervon33 Want to Buy/Trade 2 02-09-2017 04:43 PM
FS: 3rd Gen Tail Lights, Corner Lights, Cargo Cover, Running Boards mtravis8 For Sale: T4R Items 1 12-06-2012 03:42 PM
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
Clear Tail Lights, Tail Light Guards, & Many Bulbs For Sale! Fo_SheeZy 3rd gen T4Rs 21 09-11-2011 04:35 PM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
