Old 03-20-2021, 02:22 PM #16
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Originally Posted by mtbtim View Post
Do you normally wheel with a set of spare spindles?
Yep. The spindles have an SPC UBJ slugs in them and new LBJ's attached to them. They get stored behind the drivers seat along with 2 spare ITR's and L/R OTR's. I also carry a starter rebuild and alt rebuild kit in the glove box. The only thing that would make my rig a long term trail plug is motor or trans failure.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 06:12 PM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I've thought it would be smart to carry a set of extra spindles but they are quite bulky and heavy to cart around on a trip. But, I carry lots of tools and other crap so what's a couple more big bulky things to throw in the back.
Old 03-20-2021, 10:50 PM #18
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
This was 2 weeks ago. lol
I somehow wrongly thought you parted ways with the Kings after that fiasco a year or two back...
Sounds like since you got the RCV axles you no longer carry spares?
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 03-21-2021, 09:39 AM #19
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
Has anyone tried Heavy Friction Works' spindle gussets? Wondering how they fit.
HFW • Instagram
also, when I went to SPC UCAs, I welded the UBJ insert to the spindle to help reinforce the top (along with the TC gusset)
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 03-21-2021, 02:11 PM #20
Nope. I still run the Kings. They are a great shock. Their customer service and warranty on the other hand are some of the worse in the industry. Filthy Motorsports ended up giving me the shaft and rebuild kit at cost to offset the dimension of pissed off I was in. Huge thumbs up for Ben at Filthy and huge thumbs down for King supporting their product.
I do not carry spare CV's since I went to RCV's. If one goes I'll just drive out on the other one in 3wd. It's pretty much the same as a non-locked front. lol
HFW • Instagram
I haven't even heard of them. Assburns is pretty close to them. I wonder if he's heard of them.
Welding the SPC slug in would have most likely prevented the failure I had. Or at least given me time to notice it before it went catastrophic. As soon as my breaks went to the floor I knew something bad had happened on the passenger side. lol
Old 03-22-2021, 03:43 AM #21
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Originally Posted by Dezert4Runner View Post
Or better yet, use a respirator behind the mask. I miss the fume extractors that they had at the local college when I took my welding classes. It was one less thing to worry about when learning how to lay a proper bead.
Better yet PAPR with organic vapor filter. Expensive until you compare it to medical bills down the line. All kinds of stuff gives of fumes when heated like that. Rust convertor can give off phosphine. But yes at a minimum a P100 disposable respirator made for welding use.
Really should wear one for anything that generates particles, brakes, wire brushing, whatever. I wear a 3M 7500 with organic vapor cartridges just using plain old brake cleaner without the mustard gas. They are good masks. I use 7093 hard shell filters for sanding or anything they are very durable. They use them in hospitals for covid too. Regular P100 mask material is the same as the particulate layer in mil CBRN masks. Works electrostatically. You need a different layer for vapors though, the painting type.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 08:36 AM #22
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
HFW • Instagram
I'm kinda curious about those as well. I have a set of spindles from a 2wd and the TC gussets that I need welded and built out to just bolt on, but that could be an easier option.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 07:47 PM #23
rexassian rexassian is offline
rexassian is on a distinguished road
What material is the SPC insert? I thought it looked stainless or something like that? Is anyone pre-heating the spindles before welding since they are cast iron?
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 08:53 PM #24
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The spindles are forged, not cast.
Old 03-23-2021, 01:02 AM #25
calicojax's Avatar
calicojax calicojax is offline
calicojax is on a distinguished road
calicojax's Avatar
Not sure if any else has had this problem? but, I had to trim a bit of the top off of the gussets, so they would clear the strut tower. Under compression.
calicojax is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 01:50 AM #26
lawrencesam74's Avatar
lawrencesam74 lawrencesam74 is offline
Real Name: Samuel
lawrencesam74 is on a distinguished road
Real Name: Samuel
Exclamation
I have heard non-chlorinated brake cleaner was an appropriate prepping cleaner for welding. Like Jordan mentioned, we can't even get the chlorinated brake cleaner in California. But, I will add a note in the video description advising people against using chlorinated brake cleaner as a metal prep.
**Update - I just read the link Jordan provided and I'll just stop using brake cleaner altogether. It appears it's just a concern when you actually have a puddle of chlorinated brake cleaner left in a pitted surface of the metal. I've welded quite a few parts I've cleaned with brake cleaner and no reaction like the guy had in that article. I'll edit the video taking out the mention of brake cleaner and re-upload it because I'd hate to hurt anyone's health if they ended up using chlorinated brake cleaner as a metal prep.
**I confirmed that the brake cleaner I buy in California is non-chlorinated. The main ingredient in the California compliant brake cleaner is Acetone which is an accepted metal prep for welding. The other chemical ingredients are C02 and Heptanes.
Nice catch everyone. Acetone can still be no joke, my buddy at the shop I work at was welding with a bottle of acetone with a rag soaked in it on top of the bottle on the welding table next to him. Without realizing it was there, the sparks from his welding ignited the bottle, and rather than throwing his welding jacket on it or using the correct fire extinguisher, he tried to pick it up and put it on the floor, hence splashing the fiery acetone on himself.
He got his jacket off and hit it with the fire extinguisher with no injuries thank God, and I must admit the security camera video was pretty hilarious.
Recommended PPE is recommended for a reason!!
lawrencesam74 is offline   Reply With QuoteReply With Quote
3rd , chaos , gen , video , welder
Spindle gusset Dezerts10 3rd gen T4Rs 20 11-29-2020 11:22 PM
Total Chaos Spindle Gusset Brake Clip Relocation Question. Road Bull 3rd gen T4Rs 23 05-14-2020 03:46 PM
Total Chaos spindle gussets and ball joint UCA’s montijo505 4th Gen T4Rs 5 09-06-2019 05:37 PM
TOTAL CHAOS Weld-On Rear Bump Stop Mount (KING) TOTAL CHAOS 5th gen T4Rs 1 11-15-2018 06:34 PM
GA-BNIB 2" Total Chaos "Race" Long Travel -Cam/Bucket/Spindle Gussets -Axles/HD Boots av8ter For Sale: Suspension/Wheels/Tires 24 02-26-2017 05:07 PM
