Old 03-23-2021, 01:30 AM #1
Langcow1 Langcow1 is offline
Real Name: Matt
Langcow1 is on a distinguished road
Real Name: Matt
New shocks. Alignment needed?
This is probably a dumb question but I just ordered Bilstein 4600 shocks for front and rear. Once I get them in do I need an alignment?
1999 SR5 manual 4WD; 300,000 miles!
Langcow1 is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 11:34 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Yes and no. Anytime you change vehicle ride height or get new tires you should get your alignment checked/adjusted. If you are going to be close to the same height then you can probably get away with not getting an alignment.
Old 03-23-2021, 12:10 PM #3
It would be a good 'excuse' to get an alignment done, but it isn't necessary. The shocks (front and rear) do not control the alignment at all - assuming you don't lift it at the same time.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-23-2021, 12:18 PM #4
Real Name: Matt
Real Name: Matt
Cool - thanks for the info. It literally just got aligned when I re-did the front end and I’d rather not do it again after switching shocks.
Old 03-23-2021, 12:19 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Anytime I do something suspension related I do... just a good habit
Old 03-23-2021, 12:36 PM #6
Real Name: Matt
Real Name: Matt
I think what I might do is hold off on the shocks for a month and do the rear swaybar links too, and then align it again after that
Old 03-23-2021, 12:39 PM #7
Rear swaybar links won't make a difference to alignment either. Just install them whenever, especially since you got such a recent alignment.
Old 03-23-2021, 02:32 PM #8
Real Name: Matt
Real Name: Matt
I’m getting off topic now but what brands do you guys like for the rear swaybar links? I did OEM in the front but this vehicle only does light offroad so maybe I can save some $ on an alternate brand for the back - or is it better if they match the front?
I’m figuring these links and the shocks are my last two suspension repairs for now, and I’m hoping to move on to the valve cover leak after this.
Old 03-23-2021, 04:09 PM #9
What's wrong with the current links? If they are still OEM and the ball end is still in good condition, you can just get new bushings.
Old 03-23-2021, 04:28 PM #10
Real Name: Matt
Real Name: Matt
You know, they’re probably fine. I’ll double-check. I was thinking just for preventative since they are old
alignment , front , ordered , rear , shocks
Alignment gurus- help needed Soneill 5th gen T4Rs 5 01-24-2018 10:43 PM
Alignment needed? Porqupine82 General Discussions 5 02-08-2017 10:00 PM
Alignment needed? Barrie4Runner 3rd gen T4Rs 1 06-07-2012 12:39 PM
Alignment needed? NathanOfSeattle 3rd gen T4Rs 1 10-28-2010 03:04 PM
Alignment needed? ARK_SWAMP_RIDER 4th Gen T4Rs 9 01-13-2010 01:31 PM
