Old 03-23-2021, 06:22 PM #1
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Front shocks and springs options for 1.5" and 600ish lb/in?
I've currently got Toytec coilovers and 550lb springs set to roughly 1.5" of lift, but both front shocks are leaking.
I've added a plate bumper and winch, so I need stiffer coils.
Seems like anything Bilstein 5100 w/ OME coils is going to net me 2.5-3", which I want to avoid because my CVs vibrate like crazy above 1.5" at highway speeds.
What are my options besides threaded body coilovers? As I understand it 6112s are adjustable with the 600lb but that's getting into coilover money. Any other options?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 08:39 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Dobinsons has shocks/springs for us. A much less popular option but there are some reviews and info out there.
Dobinsons 2.0" Lift kit
Dobinson 2.inch lift kit vs Ome lift kit
Old 03-24-2021, 01:36 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I myself am leaning toward the dobinson 2 inch lift with the 134 and 137 springs as a kit, and the fronts assemebled.. Need heavier in the front for my arb and winch.
My last lift was 3 inch with billies and had no complaints . The lift b4 that was using 99 talls and KYB's ( b4 arb and winch) that gives you one inch and no need for diff drop or panhard correction. However in 2 years my rear kyb's were leaking....but it got pretty heavy use. with the one inch I could run the 265/75/16 on stock rims with no issues on light off road.
My current ride is so shot, ( just bought a few months ago) it wont fit even 70 series without rubbing so need to do something soon.
Vibration, you can put in a diff drop, which drops the diff about 1 inch and gets rid of that vibration and the extra wear on the cv's on 3 inch lifts. I will prob do the diff drop and the pan hard correction brackets with this new lift, even though im only going 2 inches. EK originally designed the panhard brackets for his 2 inch lift if I remeber correctly.
Ordering The dobson kits are so popular that they keep running out of them, so check on it, but dont be in a hurry. Same happens iwth the billies.
Old 03-29-2021, 09:46 AM #4
thezentree's Avatar
thezentree's Avatar
Oh man, I've been trying to solve the vibration thing for like three and a half years. I have replaced EVERYTHING that rotates in the front end. Multiple sets of wheels and tires, brakes, wheel bearings, multiple sets of CVs, ECGS front diff, with and without the diff drop. Same for the rear end. The only thing that so far keeps it at a reasonable level is to keep the lift under 1.5". I've given up trying to fix it, and just keep the lift low now.
I'll have to do some more digging on Dobinson's stuff. I want monotube shocks, but there's not a whole lot of info out there about their IMS line. That brand seems like it's really started to get popular over here in the last year or two though.
Old 03-29-2021, 10:49 AM #5
Condernr Condernr is offline
Condernr is on a distinguished road
I did a manual hub swap. Best thing for the vibration. Found a full set (spindles, hubs, and cv's) with 150k miles on them for $400. Took about an hour per side to swap out. Huge difference. Diff drops do nothing IMO.
Condernr is offline   Reply With QuoteReply With Quote
coilovers , coils , front , options , shocks
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
: 3rd G FS99 Tall Springs F+R and Front Shocks, 4R Wheels and tires, 97 springs SoCal mydogsmonkey For Sale: Suspension/Wheels/Tires 1 07-11-2014 10:36 AM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
FJ 4x4 Front shocks and Springs and Rear Springs The_B.O.W. Classifieds - buy & sell (no commercial ads please) 0 09-26-2010 11:26 PM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
