Old 03-24-2021, 10:02 AM #1
hazertag hazertag is offline
hazertag is on a distinguished road
Can someone help me figure out what’s leaking?
Noticed this leak recently. Kind of reddish, and I know Toyota uses a few different red fluids. It’s basically right under my front axle. The skid plate below all that did seem to be pretty greasy and had attracted lots of road dirt. See picture below:
hazertag is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 11:13 AM #2
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
No photos attached. If its watery it could be red coolant but shouldn't be near axle so not likely. If its oily like ATF fluid. ATF fluid runs from the trans to radiator and then back. Those lines are on passenger side of the block. Unfortunately power steering lines and reservoir are right above those at the front passenger side of the block...also uses ATF fluid. Last thought could be ATF from bell housing to block connection. With out photos hard to say but that should give you an idea of places to start searching. Good luck.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 11:21 AM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
One thing you can do: get a can of brake cleaner. Remove your skid plate if necessary, then spray the area where you see the fluid, plus a little bit above that. Spray a lot to get as much grease off as possible, then let it dry. It should LOOK dry when you're done. Then start the truck and observe the area you sprayed. When you start to see any liquid, it should point you in the direction of the leak.
thennen is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 11:23 AM #4
HTML Code:
 https://imgur.com/gallery/RADgf71
How about the above link?
Old 03-24-2021, 11:27 AM #5
thennen's Avatar
thennen's Avatar
Originally Posted by hazertag View Post
HTML Code:
The pic shows a wet spot on the ground and a wet skid plate, hard to tell more from that. I still say removing the skid plate will help.
Old 03-24-2021, 12:57 PM #6
Keep the imgur album private and share photo here using the "img" tag link you can get within Imgur when you click on a photo in your own album. I will look like this (remove extra spaces):
[IMG ]https://i.imgur.com/mW12v9U.jpeg[/IMG ]
And show this:
That looks like a power steering leak at the rack, but remove that skid plate and check. You can drive around on the street with the rear skid plate removed, so clean the area, drive a bit and check where the leak is coming from.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-24-2021, 01:06 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Have you checked your fluid levels? That's a good clue too if it's been leaking a while.
I agree on a power steering rack leak as a possible cause as your boots are wet too.
326WHP 347TQ
Old 03-24-2021, 02:57 PM #8
HiLife HiLife is offline
And the top of his skid plate too.
Old 03-24-2021, 03:03 PM #9
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
Mine was leaking from the low pressure power steering hose where it connects to the rack. Yes, it is difficult to even see it let alone change the hose.
Wedgy is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 03:20 PM #10
Awesome. I’ll hone in on power steering and go from there. Thanks for the help everyone.
Old 03-26-2021, 08:22 PM #11
watersna watersna is offline
watersna is on a distinguished road
FWIW, I had a wet spot in about the same place relative to the car and it ended up being a coolant leak from the water pump. Ran around the lip on the oil pan (I think) and then ended up flowing around back then off the skid plate. If it leaves a red residue behind when it dries, that's what mine looked like. Check coolant level in the reserve tank and see if there is liquid or deposit under the water pump.
watersna is offline   Reply With QuoteReply With Quote
Old 03-27-2021, 06:35 PM #12
Rustyboi Rustyboi is offline
Rustyboi is on a distinguished road
As someone who just replaced their whole power steering rack, I’d say that it’s likely power steering fluid. Both the high and low pressure lines are rubber/steel, and the rubber, tends to crack and start weeping. Especially if you’ve had the trans run hot before. Lmk if you figure out where the leak is. It’s a tricky spot to work on unless you remove your front tire and some of the splash guards.
An easy way to check would be starting the truck and checking for bubbles in the power steering reservoir, almost always a sure sign of a leak somewhere.
Rustyboi is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 07:28 PM #13
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
The thing is with toyota OEM coolant, this thing is reddish and pretty greassy.
I've had a few leaks on mine, and it'S very hard to tell if it's PS, transmission or coolant in small quantity. Coolant gives the same oily feel as the rest, when taken from the ground.
I would first check your coolant level, if it's below level, be pretty sure it's a hose leaking. Could be MANY things, as hoses are getting older on this. Had a few hoses leak over the years, for no apparent reasons.
Next, look at your transmission fluid, and if it's that on the ground, you can often ''smell'' the bad smell of it. You don't want to go low on coolant nor on transmission level. PS level going too low, at the worse, you'll lose power steering and use power arms to turn, and have to change a pump, much better than replacing a trans or an engine.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 12:46 AM #14
Jcray19's Avatar
Jcray19 Jcray19 is offline
Jcray19 is on a distinguished road
Jcray19's Avatar
I experienced something similar on my last third gen and it ended up being the steering rack, right next to the boot on the drivers side.I think the rack would be a good place to start.
1999 4runner SR5. Auto. Bilstien 5100s. K02s
Jcray19 is offline   Reply With QuoteReply With Quote
axle , front , plate , pretty , skid
Sunroof or windshield leaking? Can't figure it out muellernautique 3rd gen T4Rs 1 01-27-2018 07:37 PM
Please help me figure out what to do next. psraff 3rd gen T4Rs 15 03-23-2016 11:52 PM
Rear differential leaking housing leaking? Schwooby Classic T4Rs 5 07-01-2014 06:43 PM
Figure this one out! sant6236 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 11-04-2008 05:50 PM
Paging Stick Figure, come in Stick Figure, do you read, over? riverrat44 3rd gen T4Rs 1 09-04-2008 11:53 PM
