03-23-2021, 02:21 PM
Real Name: Josh
Real Name: Josh
The milkshake syndrome
Everybody talks about the strawberry milk syndrome. But what about if it's chocolate milk looking?
03-23-2021, 02:44 PM
Sure it’s not just really dirty trans fluid mixed with red coolant?
03-23-2021, 02:47 PM
Real Name: John
Real Name: John
Pics?
00' SR5 250k 4X4
Inside LEDS, Rear Diff breather, mini roof rack, front mud flaps, Magnafine Inline Trans filter, kicker speakers, sound deadened doors
03-23-2021, 03:49 PM
Chocolate milkshake is often engine oil and water/anti freeze.
Where do you notice the milkshake?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
03-23-2021, 04:11 PM
pink milkshake = red trans fluid + toyota red coolant
chocolate milkshake = old trans fluid + normal green coolant
Both are bad...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-23-2021, 06:26 PM
Real Name: Josh
Real Name: Josh
[QUOTE=cas5259;3619549]Sure it’s not just really dirty trans fluid mixed with red coolant?[/QUOT
I erred by putting green stuff in but i'm thinking that green and red make brown i think
03-23-2021, 06:27 PM
Real Name: Josh
Real Name: Josh
Originally Posted by JDG2000
Pics?
how do i upload pics?
03-23-2021, 06:28 PM
Real Name: Josh
Real Name: Josh
Both are bad...
prob what it is
03-23-2021, 06:29 PM
Real Name: Josh
Real Name: Josh
well i flushed 3 gal of atf and now its becoming very light red. I will probably need 2 more jugs
03-23-2021, 06:31 PM
nothing wrong with using green coolant. before the advent of the red/pink coolant, Toyota was using green coolant.
it's just that the red/pink coolant has a longer life than the green coolant so you don't need to change coolant as often.
[QUOTE=josh3rd;3619625]
03-23-2021, 10:23 PM
Real Name: John
Real Name: John
You can attach them in a message. Look for the paperclip.
00' SR5 250k 4X4
03-23-2021, 10:56 PM
Real Name: 3 Bears
Real Name: 3 Bears
[QUOTE=HiluxSurf SSR-G;3619630]nothing wrong with using green coolant. before the advent of the red/pink coolant, Toyota was using green coolant.
I thought there was an acidity or chemical difference too
03-24-2021, 02:07 AM
yes, there are chemical differences (i forgot what) and it becomes acidic when it goes beyond the recommended change period of 5 years.
but as i understand it, the main intent was to use a coolant that lasts longer.
Also, to the OP, don't mix red and green coolants. that's very bad. flush the cooling system, including the heaters, before changing coolant
[QUOTE=3bears;3619714]
03-26-2021, 07:22 AM
Real Name: Josh
Real Name: Josh
Truly appreciated feedback fellas. I seen somewhere in the replies someone had asked "where" was this noticed at. Well when I checked the coolant res and noticing that it was empty, I looked at the rubber tube that goes inside the container of the res and seen the bottom opening of the thin tubing and it looked like a chocolate shake than a strawberry.
Then checked the trans stick and it showed regular tran fluid. Clear and red tinted like it was just newly poured.
The next day after the tow checked the trans level and clarity and boom, milk shake.
Everyone yesterday I had put a total of 28qts of ATF to cleanse the trans and it looks like a dart, dingy pink or light red. But no clarity at all. So how many quarts did those who had the milkshake issues before it became clear? Thanks in advance
03-26-2021, 08:18 AM
did you replace the radiator before flushing the transmission? the milkshake occurs because the stock atf cooler in the radiator has rusted through, thereby allowing coolant to mix with the atf.so if you didn't replace the radiator, or bypass the stock atf cooler with an external atf cooler, then milkshake will happen again.
