Well if you are like me and don't care to have a sunroof (moonroof) and are paranoid of it possibly being "stuck" open, please continue reading and enjoy my first "write up".
I have searched and personally looked and checked for a "fuse" for the moonroof and I could not find a specific fuse for it to pull out. So I did a quick search on how to access the motor and I still did not find anything other then its above the map lights. Here I will show you exactly how to gain access to the motor itself fast and easily.
Proceed this mod at your own risk, I am not liable for any damages or anything!!!
Tools needed, a "flat head" screw driver, a Phillips screw driver and some electrical tape.
Look closely for two "notches" between the clear lens and plastic frame. Gently pry apart with your "flat head" screw driver.
Once you have removed the clear lens, take your phillips screw driver and remove this screw.
Next, gently pull down and out (towards rear of T4R) the whole map light piece.
Here is the plug that you will need to disconnect by pressing down on the tab, and pull the two plugs apart.
Next, I taped off both plug ends, you may not (need) to do this, but I did because I don't like "open" connectors. Then to get the plug out of the way, I taped it to the wire harness for the map lights.
Last step, gently push down on the tab that holds the motor side plug to the bracket, and continue to tape off this plug also. When done simply push the plug back onto the bracket until the tab "clicks" back into place.
Reinstall everything in reverse order and you are DONE!
