03-26-2021, 03:54 PM
3rd Gen SAS - Axle/T-Case Options?
Picked up a 00 Runner auto for my next build. I've been outta the game for a while so need a gut check.
Purpose: Drive family of 4 all over west coast, crawl over rocks (rubicon/fordyce, utah, colorado, etc), drive home, get slightly better fuel economy than a fj80.
Front will be 3 linked, leafs in the rear, 37's, double locked...
What axle/t-case combination would you choose and why? Options i'm considering below, but open to others (toy axle only).
1. Trail gear crawl box, in front of stock chain case to stay drivers drop. Simple, chain case is probably strong enough for my purposes. I'd go marlin, but tcases are getting harder to find in good condition, marlin never has stuff in stock, and trail gear will just send me a built unit to make it easy. Axle would then be either diamond or ruff stuff with mini outers.
2. Atlas 4-1, with fj80 front. T-case is expensive and probably overkill, but the front axle becomes much cheaper (add hellfire knuckles, longs, selectable hubs).
3. Does anyone make an adapter behind the auto to use passenger drop gear duals anymore (don't want to go the t100 chain case route)? If so, i'd probably go this route with an fj80 axle. Relatively inexpensive for enough strength.
Appreciate the feedback.
03-26-2021, 11:03 PM
If you are dead set on Toyota axles, what you've said is what you've got. If you do go FJ80 outers on the axle, Front Range Off Road just released their keyed steering knuckles, a little less expensive than Hellfire Knucks. Slee also makes a cheaper high steer option. Advanced Adapters, Trail Gear, and Marlin all make adapters behind the tranny to use a gear-case crawl box. You can even buy complete dual cases (gear driven, passenger side drop) from TG that bolts right in.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
03-27-2021, 12:23 AM
If you are interested, I have a new TG adapter plate I can sell at a discount (this one here, TACOMA T-CASE ADAPTER PLATE KIT) that I probably won't end up using (I'm probably going to end up getting an Atlas or Blackbox when I do my SAS).
03-28-2021, 10:35 AM
Official Vendor
Official Vendor
Originally Posted by Team_Jake
I If you do go FJ80 outers on the axle, Front Range Off Road just released their keyed steering knuckles, a little less expensive than Hellfire Knucks.
Really?! I'm on a waitlist for Hellfires, but would certainly look into the FROR stuff..
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
03-28-2021, 12:16 PM
Yep, a few days ago they posted this on Instagram:
03-28-2021, 06:54 PM
Official Vendor
Official Vendor
I dig it. - I'm a little concerned about how wide the key is (or how little material is on the sides, without a meaningful fillet in there) - looks like a good place to start a crack to me?:
might be totally fine with the bolts in place; I dunno.
keith
eimkeith.com
03-29-2021, 10:49 AM
Didn't know about the FROR option, thanks for the intel! I'm aware of the Slee option, but want sometime a bit stronger. I've had the hellfires on my old 4runner (also linked 80 front) and they were easy to set up and issue free.
Buying the dual ultimates from trail gear is pretty appealing, but 2.28x4.7 with an auto seems way too low...maybe just a single 4.7?
03-29-2021, 12:23 PM
Well you could always do 2.28x2.28 duals. That’s what I’m doing except I’m keeping my multimode case and doing 2.56x2.28.
03-29-2021, 01:27 PM
I may be interested, will definitely keep you in mind. I really need to commit to an axle...most likely going FJ80 passenger drop mainly for cost. No custom housing needed, i'd need to source a mini truck axle for a mini outer solution anyways and those are getting hard to find in decent shape. With FJ80 i'll be passenger drop, gear driven case, and will need this adapter.
03-29-2021, 03:41 PM
For a fully built trail gear option, looks like 2.28x4.7 is the only option on the website. I've built crawl boxes before, but finding 2 gear driven cores in good shape is becoming a challenge.
This would likely be the route i went if staying driver drop (add crawl box in front of factory chain case).
03-29-2021, 04:13 PM
Ah, that makes sense. Just thought I would throw it out there. When I was looking for my crawlbox it was a pain finding one. I realized you can’t look at Craigslist or Facebook market place, only places that had them were Toyota specific salvage yards. Even looked at pick n pull, 99% of them were 2wd. Marlin crawler told me to use some guy in Colorado, he wanted 500$ for one shipped to me lol. I went to a local Toyota salvage yard (Nor Cali) and picked up a 79-83 case for 150-200$, he said they usually get one about once per week.
03-29-2021, 05:16 PM
Damn, $500 each is crazy. Thinking 2.28x4.7 built unit from TG makes the most sense at this point. May be getting an FJ80 front this weekend.
03-30-2021, 11:31 AM
I’m in the same boat. I called all my toyota friends in WA and none of them had an extra case to spare. Called around all the Toyota yards and they wanted $500 for the case. I’m about to call back home in HI to get a case and ship it up here in WA.
Busmup808 all day, all night!
03-30-2021, 01:14 PM
Car-part.com is your best bet for a gear drive transfer case, ~$250 in my area. The best gear drive T-case option is the top shift case found in early 22RE engines, look up 1988 Toyota Truck, 4 Cyl, MT.
03-30-2021, 02:09 PM
Top shift case years:
79-83 (all) 85-88 (4cyl EFI only)
Transfer Case Bible | Marlin Crawler, Inc.
