Old 03-28-2021, 03:17 PM #1
Kwikvette's Avatar
Kwikvette Kwikvette is offline
Kwikvette will become famous soon enough
Kwikvette's Avatar
Rear King Shocks clearance
So, I've owned my 4Runner a few months now.
I bought all new King 2.5 front and King 2.5 rear at the same time; also have the appropriate longer Durobump stops and OME890 rear springs for 2" of lift since I have a dual swing out.
With that being said, I installed all my own suspension per the instruction manual (not my first lift on any vehicle).
The rear shocks are side specific, due to the reservoir orientation.
I reached out to King about my issue, so while I wait to hear back, I want to gather thoughts here.
Do you have issues with either the frame contacting the hose fitting, or the reservoir body contacting the sway bar?
If I orient it where the sway bar doesn't hit the body, the hose fitting hits the frame. It got bad enough that I now have a small dent in the reservoir body and it sucks that this happened to shocks that are only months old.
Rear King Shocks clearance-5-jpg  Rear King Shocks clearance-6-jpg  Rear King Shocks clearance-20210327_174836-jpg  Rear King Shocks clearance-20210327_174908-jpg  Rear King Shocks clearance-20210327_193319-jpg
Kwikvette is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 04:21 PM #2
fixxor fixxor is offline
fixxor will become famous soon enough
Well you definitely need longer sway bar links, thats an extreme angle and stress i would say your mount bracket is bent but cant really tell from the picture.
1997 3.4l w/ locker: Radflo 2.5 w/ adjusters front, OME 861 rear with LC shocks, 265/70R17 BFG KO2, TJM front bumper, 4x innovations rear bumper, 4x innovations sliders, Prinsu roof rack, ARB 2500 Awning
fixxor is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 05:00 PM #3
Kwikvette's Avatar
Kwikvette's Avatar
The second picture looks that way, but that's because I unbolted the end links to get enough droop to install my springs.
They are not bent at all.
After looking at everything yesterday, it seems like longer sway bar end links would indeed help...but these shocks are meant as an OEM stock height up to a 2" lift. So the damage is already done.
No mention of any other modifications IE sway bar removal or longer end links in either the provided instructions, or on any website from any and all authorized dealers.
Old 03-28-2021, 06:14 PM #4
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
there was a post a few weeks ago in this forum about using a separate mount for the reservoir to avoid that kind of damage to the reservoir
EDIT: here it is:
King piggy sway rub
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 06:34 PM #5
Kwikvette's Avatar
Kwikvette's Avatar
EDIT: here it is:
King piggy sway rub
Thank you for this.
Sucks that this happens on a pair of shocks only months old.
May have to buy some Bilstein 5100s as a temp back up while I try to get a new reservoir body.
Old 03-28-2021, 10:19 PM #6
My bad now i see the mount now. Looks like you can get longer links or mount the reservoir somewhere else.
body , king , rear , reservoir , shocks
King long travel rear shocks GX4SEVEND 5th gen T4Rs 12 10-07-2019 10:11 PM
Rear King Shocks for 3" OME Springs chmura 5th gen T4Rs 4 03-08-2019 07:55 PM
Will rear King LC shocks fit on a 99 4runner? Rambler808 3rd gen T4Rs 8 12-21-2017 06:48 PM
Question For Those With Rear King Shocks Kirk_B 3rd gen T4Rs 4 02-27-2017 04:21 PM
Which rear shocks to use with king c/o's Rambler808 3rd gen T4Rs 1 05-10-2016 10:16 PM
