Old 03-28-2021, 07:35 PM #1
whiskeybob66 whiskeybob66 is offline
whiskeybob66 is on a distinguished road
02 parts worth upgrading to for a 2000
I have a 2000 limited that I am about to start working on and building up. As luck would have it, my brother in law recently blew the motor on his 2002 4Runner limited. Heís ready to move on, but told me if thereís anything I wanted off of his for mine to have at it. Is there any major upgrades or improvements on an 02 that are worth taking? Mechanically my 2000 is solid other than maintenance parts that are needed. I see people talk about the tail lights a lot, his has heater front seats and I donít. Anything else worth scrounging?
2000 Silver t4r limited Stock...for now
whiskeybob66 is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 09:41 PM #2
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough
Cree's Avatar
If you need nothing, there's nothing worth messing with between the years. You actually have the more desirable of the two.
00 Limited - Stuff!
18 A6 3.0T - No stuff, Just boost
Cree is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 10:02 PM #3
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
It's actually the other way around, 99-00 has the desirable parts. Lots of things became integrated or went electronic in 01 and became very expensive as a result. Look at the TB/IAC for example.
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / CVJ 9168R Axles / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / Braided + Extended Brake Lines / Extended Sway Bar Links / Elbow Delete + ISR / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod
Devbot is online now   Reply With QuoteReply With Quote
Old 03-28-2021, 10:10 PM #4
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold
JZiggy's Avatar
Tail lights and harnesses
Sun visors may have homelink or slide outs
The weird looking 01-02 front grille if that’s your speed
Rear seat backs have the toddler seat tie downs integrated
All I can think of off the top of my head!
JZiggy is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 11:35 PM #5
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
I would grab the headlights, corners and tail lights for spares. I would grab the throttlebody and the master brake cylinder, you can sell them on ebay for a few bucks. You might also want to pull the antenna for a spare as well, and maybe one of the wheels to use as a spare. You can sell the center console. If you have time pull the front and rear diff for spares, as well as the cv axles. you should be able to fit all that in a couple of black and yellow crates from costco.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 12:12 AM #6
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough
Instead of raiding the truck for a few trinkets, what about making an offer for the whole shebang and find a replacement motor. Could be a nice payday.
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 01:46 AM #7
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
the heated seats could be nice, the later tail lights with harness, if the headlights and corners are still toyota get those.
otherwise, not much in my opinion
2000 SR-5 Highlander. bought 6/16/20. 4:30's, factory locker, Green
2001 SR-5.. bought 12/10/20. thunder cloud metallc, problem child...
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, TOTALED 10/22/20.
Old 03-29-2021, 09:48 AM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
This is The correct answer!
2001 Limited 4WD - 331+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
limited , major , parts , upgrades , worth
Is upgrading a 12 year old 4runner worth the cost??? Drummer1 4th Gen T4Rs 35 05-13-2018 12:25 AM
Worth upgrading to 2008 Sport V8 from 2006 Limited V6? metramm 4th Gen T4Rs 22 11-15-2016 02:29 PM
Is it worth changing/upgrading things if you plan on selling for a new model minimalist 5th gen T4Rs 17 11-03-2016 01:45 PM
Is it worth upgrading to 2014 Trail? Cire2 5th gen T4Rs 17 05-27-2014 05:18 AM
Upgrading the brakes on a '96 with '02 Tundra parts pencil_&_paper 3rd gen T4Rs 5 03-12-2011 05:13 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
