Old 03-29-2021, 12:43 AM #1
ViaPhoenix ViaPhoenix is offline
ViaPhoenix is on a distinguished road
ViaPhoenix's 97 SR5 Build Thread
ViaPhoenix's 1997 4Runner SR5 4x4 w/ Factory E-locker
I bought this in Nov '18 because I wanted learned to wrench on vehicles and eventually have a rig to start exploring further offroad than my outback could take me. As well as, having a non-daily driver that I do not care about the AZ pin striping and any body damage that could come. I have lurked this forum a lot and followed Timmy&Sean's lead over at Toyota Time a lot. So much thanks to all of you that have unknownly helped me tackle all these projects and buy way more tools than I thought I'd ever need.
Specs & List of Mods:
Engine:
  • 3.4L 5VZ-FE V6 - 291k miles as of Jul '21
  • Hood strut mounts - Jan '19
  • Removed previous owner's K&N filter and found junk yard OEM airbox from 99-02 runner with the cheaper MAS than the 96-98 (had to repin plug) - Mar '19
Diffs/Transmission:
  • Rear Factory E-Locker swapped from a 98 limited Completed - Mar '21 - Rear Axle Swap Photos
  • E-Locker Wiring harness from 12VoltGuy - Mar '21
  • 4:88 Nitro Gears, regeared by ZUK @ gearinstalls.com with cryo finish - Dec '20 - Photos from ZUK
  • CVJ Axle Remans - Mar '21
  • 1" front Diff Drop toytec - Mar '21
  • Extended Rear Diff Breather - Mar '21
  • New Rear U-Joint - Mar '21
  • Magnefine Trans line filter - July '21
  • MaxTow Transmission Temp Gauge - July '21
Lift/Suspension:
Front:
  • Old Man Emu Shocks and springs (881) ~2.5" lift - Mar '21 - Front Suspension Photos
  • New OEM LBJ, UBJ, UCA Bushings - Mar '21
  • New Serberian bushings for LCA/Steering Rack/Sway Bar - Mar '21
  • Overland Offroad Endlinks - Mar '21
  • DuraBump bumpstops and differential support arm bushing - Mar '21
  • JBA UCA on order - Aug '21 - installed Jan '22
  • Manual hubs - Junk Yard find - Aug '21 - Installed Jan '22 - Manual Hubs
Rear:
  • Old Man Emu Shocks and springs (890) ~2.5" lift - Mar '21 - Rear Suspension Photos
  • Replaced OME 890s with LC80 7.5 Wraps (Toyo part# 48131-6A480) - Dec '21 - LC 7.5 wrap photos
  • New Serberian bushings for Upper&lower Shock/UCA/LCA/PanHard/Sway Bar - Mar '21
Tires/Wheels:
Brakes:
  • Big brake upgrade - 231mm Tundra Calipers/pads/rotor/rebooted and painted black. Installed June'21
Armor:Future Armor:
  • EIM Keith Lower Link Mount Skids/Reinforcement Painted, just need to be welded on
Exterior:
  • Gobi Roof Rack - Oct '21
Interior:
  • Center Console Mod from 99-02 4runner - Mar '19
  • Noico Sound Deadening - Rear May '19 - Front Mar'21 - Sound Deadening Photos
  • New Carpet from stock interiors - Mar '21 - New Carpet Photos
  • LED light bulbs from superbrightleds.com - July'21
  • 99-02 passenger rear side panel mod - May '21
  • Atoto A6 Pro Stereo - May '21
  • Hilux Surf Field Monitor Unit - July '21 A couple FMU photos
  • Outbound Nevada Molle Panel - Aug '21 Outbound Nevada Molle Photos
Future Interior:
  • Rear hatch window switch on rear hatch
  • Rear hatch door latch on rear hatch
Maintenance:
  • Trans/Diffs/Oil drain fill - Multiple times
  • Driveline Zerc fitting greasing - Multiple
  • Braided Front brake lines - Feb '19
  • New Value Cover gaskets - Mar '19 - Value Gasket Photos
  • New OEM Timing Belt/Waterpump - Mar'19 - Timing Belt Photos
  • Learned the hard way that not all AC Mount bracket are equal mine had a 99+ bracket
  • New OEM Radiator / Toyo Pink coolant - Apr'19
  • New OEM Rear Wheel bearing and axle seals - Mar '20
  • O'Rielly's Alternator went out 30 miles from home on a Sunday ;( - June '20
  • New rear brake drums and shoes - Sept '20
  • New Throttle cable - Sept '20
  • New Battery Autozone - Dec '20
  • New Transfer Case OEM oil seal to rear drive line - Mar '21
  • New OEM Innner/Outer Tie Rods - Mar '21
  • Junk Yard Oil Pan replaced while Front Diff was out, old was leaking at drain plug - Mar '21 - Oil Pan Photos
  • New Fuel Injectors from Motor West - Mar '21
  • Cleaned door contacts and added dialectic grease to all 4 doors. June '21
  • New Trans Oil pan (35106-35100) July'21
  • Trans oil filter (35330-60020) July '21
  • Replaced Negative Battery Terminal (90982-06022) July'21
  • magnafine filter July '21
Future Maintenance:
  • External trans cooler
  • Transfer Case still has small leak, higher that the Rear drive shaft seal on something facing the passenger side, more discovery needed
**I am unoriginal and stole format from brain2sun, so please and thank you.
ViaPhoenix's 97 SR5 Build Thread-img_20190527_112550-jpg  ViaPhoenix's 97 SR5 Build Thread-img_20210522_110435-jpg
Last edited by ViaPhoenix; 01-20-2022 at 10:38 AM. Reason: Manual Hubs and JBA UCAs
ViaPhoenix is offline   Reply With QuoteReply With Quote
front , mar , oem , photos , rear
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
