Old 12-08-2021, 04:31 PM #16
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by Sawdog View Post
Thanks Kanoe, the symptoms were so similar to the clutch switch my mind first jumped there, definitely could be the starter. I'll have to look back through my records but I believe it is original.
Did you try using the clutch bypass switch on the dash? If it starts fine, then your clutch switch is the issue. If it doesn't, then starter contacts are a good bet.
My Backyard Frame Swap
Old 12-08-2021, 11:01 PM #17
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
If you need to replace the contacts in the starter - part numbers
28226-54340 (one contact kit)
28226-72010 (the other contact kit)
28235-74130 (plunger, magnetic) <-NOTE had to shorten rod by 28mm (to 40mm length)
I did this 8 years ago and this is what I have in my notes, so I don't know if I got the wrong part number or part for the plunger, but apparently it was easy enough for me to shorten it.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 10:31 AM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Is there only one starter option for manual transmissions? I know there are 2 different starters that came with the 3.4L engines.
Old 12-22-2021, 10:34 AM #19
Sawdog Sawdog is offline
Sawdog is on a distinguished road
Originally Posted by Hvacman View Post
So I just bought a hi mileage ‘96 5vze - 5 speed and having starter issues similar to above.
I keep reading I should save/repair the starter vs. buying a replacement, but how do I know its not a cheapie already in place?
Is there a way to I.D. The starter while its in the vehicle?
Thanks
OP here, just as everyone said, it was indeed the contacts. Getting the starter out was a royal PIA- other than that, easy job. Spent a good hour trying to wiggle the starter out, rest of the job took 20 minutes. I used this kit.
Amazon.com: Victory Lap ND-34SOL Solenoid Repair Kit : Automotive
Sawdog is offline   Reply With QuoteReply With Quote
Old 01-03-2022, 09:18 PM #20
I've read that before, but when I pulled mine I remember it was maybe 15 min including getting the 4runner on my scissor lift. Then I looked through my maintenance records and I installed a 1" body lift before the starter contacts needed replacing...so body lift might make this job easier.
clutch , depressed , manual , start , switch
Crank no start thecole1098 3rd gen T4Rs 10 07-21-2018 07:44 AM
Crank no start 4runneracerunner Classic T4Rs 35 08-19-2017 04:46 PM
New trans cooler and radiator - should I get rad for manual trans? dogbreath650 3rd gen T4Rs 3 06-06-2017 02:14 PM
Automatic trans to manual trans zachoffmn1 Classic T4Rs 3 07-31-2015 01:00 AM
Crank, NO start... Please help! VALERIEP81 3rd gen T4Rs 7 12-15-2009 08:05 PM
