Old 04-02-2021, 12:59 PM #16
Originally Posted by giguchan View Post
Didn't know the drains were IN the Sunroof..
There's a lot i don't know about my Runner it seams... I'm going to try this..
Thanks.
Every sunroof leaks and they ALL have drains, one on each corner. It is a an issue every sunroof vehicle might have if the drains get clogged.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-02-2021, 03:53 PM #17
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
I was just getting ready to say that ALL of them don't leak but then i remembered a post i once posted.
Sunroof Leak.. My Turn...
So i guess yeah... they sure do.
Gonna try to get to the Drain thing this weekend. I know that people use Weed Wacker line.. I was wondering if a Air Compressor(not a can of Compressed air) would be a little bit more efficient.
I guess when using line you know for sure that the drain is clear.
Thanks.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 05:21 PM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks.
If you blow too much air pressure into the sunroof drain you risk the line coming off at the sunroof assembly or it could separate at a joint/splice if they have any on that line. I'd stick with trim line
Old 04-03-2021, 12:05 AM #19
giguchan's Avatar
giguchan's Avatar
Hey,
Yeah, i think that's what i am going to do. I have a wire snake for pulling wires but i think i'll stick with what everybody else is using. To tell you the truth the Weed whacker line is probably the easiest and safest way to tackle this job.
Thanks.
Currently 194K
Cheers
Old 04-03-2021, 01:13 AM #20
Washingtonian Washingtonian is offline
Washingtonian is on a distinguished road
I had water on the front passenger floor. Found it was leaking from the rubber windshield seal. The previous owner replaced the windshield a couple of years ago. I put a few feet of black plastic electrical tape between the windshield and rubber seal and the roof and the rubber seal and it seems to have fixed it. The car is black, so not noticeable unless you look for it.
Washingtonian is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 02:30 AM #21
Zoom-a-Loom Zoom-a-Loom is offline
Zoom-a-Loom is on a distinguished road
Windshield leak most of the time due to a replacement windshield after market rubber rain strip. Use OEM rubber windshield dam. also can cause rust to form in the pinch weld hidden by the windshield
Zoom-a-Loom is offline   Reply With QuoteReply With Quote
cracks , good , leak , raining , strange
Electrical short when raining? dmalis12 4th Gen T4Rs 1 12-21-2013 08:58 PM
Roof Noise when raining?? JLRSR5 Problems & Warranty Issues 0 08-21-2013 06:50 PM
1988 Hesitates when raining LostinDartmouth Classic T4Rs 9 05-08-2011 06:51 AM
Dudes and Duedettes, its been raining for days magnumfan Nor Cal 3 05-04-2009 01:31 AM
