Old 03-31-2021, 05:13 PM #1
wrpsuite wrpsuite is offline
wrpsuite is on a distinguished road
Leak in cab when raining
Anyone tell me what’s happening here water pouring in when raining and I back up ? The molding looks good no cracks, really strange. Thanks
wrpsuite is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 06:11 PM #2
99problems's Avatar
99problems 99problems is offline
99problems is on a distinguished road
99problems's Avatar
I've got the same issue. After a heavy rain and I get into the car and back up a rush of water comes pouring out the top of the windshield and pours onto the steering wheel and my lap. I'm thinking that heavy rain causes a build-up in the sides of the sunroof area and seemingly can't drain fast enough (drain lines are as clear as I can get them). I think it's from the sunroof surround (the fuzzy part outside of the plastic) contracting/wearing down over time and letting more rain get into the area than would have when it was newer. It also seems to leak down the driver side B pillar and soak the rear passenger footwell area pretty thoroughly. I'm trying to come up with a fix that doesn't involve sealing the sunroof shut or replacing it outright since it's $$$$$$$ as hell. This wasn't a problem in Colorado, but since moving back to the South the rain is sufficient to cause this little headache. Let me know if you find a solution.
Bilstein 5100 shocks and OME 2881/2906 springs; Tundra brake upgrade w/ SS lines front & rear; Big-3 electrical upgrade; Airaid intake.
99problems is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 06:20 PM #3
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
If you have a sunroof, check the drains.
If you don't, check your roof rack. The bolts that hold the tracks MUST be sealed with silicone when they are put in.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 03-31-2021, 06:55 PM #4
rickmum's Avatar
rickmum rickmum is offline
rickmum is on a distinguished road
rickmum's Avatar
Another vote for roof rack bolts.
Back em out, pump a bit of silicone in there and install again.
For the rails bolted directly to the roof.
1998 Desert Dune Limited w/ rear diff locker
300,000 kms
rickmum is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 07:04 PM #5
99problems's Avatar
99problems's Avatar
I'll give this a try tomorrow when it stops raining. I'm also going to make sure the drain plugs are clear.... recommendations for cleaning them out? I'm thinking some Dawn water, can of air, and some dressing (like Armor All, not ranch).
Old 03-31-2021, 10:24 PM #6
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I think you can snake the sunroof drains with something like weed whacker / string trimmer wire?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 10:37 PM #7
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Add me to this list also. Last week it was the by the drivers door(almost the same spot the photo shows) and this week it was by the rear hatch.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 10:38 PM #8
giguchan's Avatar
giguchan's Avatar
Drain plugs... is there a "write up" anywhere on this? or is it that simple to fix
Thanks.
Currently 194K
Cheers
Old 03-31-2021, 10:41 PM #9
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Wouldn’t the head liner be soaked if it was the sunroof? Are you sure it’s not coming in around the door moulding? The top most rubber is a drain channel, maybe it’s full of dirt and causing a backup there?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 11:42 PM #10
Real Name: Jerod
Real Name: Jerod
It could be the door molding if it's torn at the top. It would be pretty obvious though.
326WHP 347TQ
Old 04-01-2021, 10:53 AM #11
99problems's Avatar
99problems's Avatar
Well I think I found the culprit on my end and it turned out to be a much easier fix than I imagined. I opened the sunroof and used a pump sprayer with some hot water and Dawn to test the drains. Front two drains were perfect and immediately ran free and clear out behind the front tires. Passenger side rear drain also ran a nice stream out behind the rear tire so no problems there. Driver side rear drain..... just a tiny drip between the seams in front of the rear tire. Luckily Dawn is amazing so I let it power through whatever crud was stuck in there and after a couple minutes I sprayed more hot Dawn water in the sunroof drain channel; repeat until ~10 minutes later and everything appears to be draining well. I even bought some weed whacker trim line that I won't be needing now. I'm still going to go ahead and back out the roof rack screws and add some silicone and re-tighten them down per the advice of rickmum, but this looks like it was an easy fix that I should have done a month ago.
Old 04-01-2021, 01:39 PM #12
99problems's Avatar
99problems's Avatar
Unscrewed the roof rack (5 torx bolts on each side) and pulled it off to reveal the nastiest bit of paint I've seen in quite a while. Got it cleaned up and ceramic coated (also cleaned and silicone sprayed the bottom of the roof rack rails) before applying a dab of silicone goop into each exposed hole and reattaching the roof rack. Picture of the grossness:
Leak in cab when raining-underneath-jpg
Old 04-01-2021, 01:55 PM #13
99problems's Avatar
99problems's Avatar
Thanks.
I found something even better than a write-up. Turns out Timmy made a whole how-to video on clearing the drains (and removing the headliner if you need to do that): https://www.youtube.com/watch?v=MVJW...ture=emb_title
Old 04-02-2021, 12:39 AM #14
giguchan's Avatar
giguchan's Avatar
Didn't know the drains were IN the Sunroof..
There's a lot i don't know about my Runner it seams... I'm going to try this..
Thanks.
Currently 194K
Cheers
Old 04-02-2021, 12:40 AM #15
giguchan's Avatar
giguchan's Avatar
Thank you.. i'm going to have a look.!
Currently 194K
Cheers
cracks , good , leak , raining , strange
Electrical short when raining? dmalis12 4th Gen T4Rs 1 12-21-2013 08:58 PM
Roof Noise when raining?? JLRSR5 Problems & Warranty Issues 0 08-21-2013 06:50 PM
1988 Hesitates when raining LostinDartmouth Classic T4Rs 9 05-08-2011 06:51 AM
Dudes and Duedettes, its been raining for days magnumfan Nor Cal 3 05-04-2009 01:31 AM
