Old 04-03-2021, 12:53 PM #1
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Scangauge ll
Anybody has this product? I got it free and I’m trying to clear a ENGINE, VSC OFF, & VSC TRAC lights on my wife’s 07 Limited Sequoia. I have no SCAN display and I’ve searched the PDF on their website and no luck.
Here’s what I’m showing from initial start
Here’s what it shows when I press MORE
Here’s the version I have 4.52
If anyone of you can help me out, you are greatly appreciated. Alojah from WA. Scangauge ll
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 02:23 PM #2
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Scan gauge 2 will only read CEL codes. If definately doesn't read SRS codes. So im sure it won't read any other independent system such as ABS, TRAC, or VSV. Sorry my braddah. I may be wrong though...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 06:26 PM #3
busmup808's Avatar
busmup808's Avatar
I’m missing the HOME page
This is what the home page should look like according to Scangauge
Old 04-03-2021, 06:45 PM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
in case you need further info after using what @busmup808 shared, you can readily google to find the URL for the manual, and then use that to go through the programming to set up your main screen. if i take mine out of the 4R and put it into my truck, then swap it back to my 4R, it gets kinda jangled for the first use or two. if you keep it plugged in to the same vehicle, i believe it should calm down and keep your settings for you.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 07:13 PM #5
As soon as mine connects it goes strait to my gauge screen.
The lower right button below the display is the back button. Pushing it should take you to the screen you say is missing.
Old 04-03-2021, 08:05 PM #6
busmup808's Avatar
busmup808's Avatar
I had it hooked up in my 98 4RUNNER and plugged it in my wife’s 2007 Limited Sequoia. I didn’t set it up in my truck and I did set it up in my wife’s truck. I’ll keep it in her truck to see if it starts reading it. I just plugged it in this morning
Old 04-05-2021, 02:09 PM #7
It should show the scan function once it is actually connected to the ECU. It should just take a few seconds (up to maybe 15?).
The VSC and TRAC lights may just be on because the CEL is on - fix the CEL first, then see if there are other issues.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
here’s , i’m , press , version , vsc
Scangauge 2 need help!! PCF4runner 3rd gen T4Rs 3 10-20-2016 07:39 PM
Scangauge 2 Bumbo 4th Gen T4Rs 17 08-13-2016 04:39 PM
Ran out of gas.....with a Scangauge II nc-grayson 3rd gen T4Rs 25 05-17-2016 11:04 PM
ScanGauge II as anyone used it? PCF4runner 3rd gen T4Rs 34 02-17-2016 03:27 AM
WTB Scangauge 2 PhdNPrerunners Want to Buy/Trade 1 06-18-2013 12:15 PM
