Old 04-04-2021, 12:42 PM #1
ch1966 ch1966 is offline
ch1966 will become famous soon enough
01-02 with Eaton Truetrac
Anyone have this setup?
I’m wondering how atrac vsc and limited slip interact.
Is it worth it.
Thanks
ch1966 is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 01:51 PM #2
spartacus's Avatar
spartacus's Avatar
Is it worth it.
Thanks
The 4runners don't have lsd. There is Trac system that stops the wheels from spinning if both wheels are on the ground and center diff lock to engage front and rear. There are a bunch of folks running with trutrac or detroit. It gets a little getting used to but generally folks like it.
Anyone running a Tru-Trac in the rear?
Old 04-04-2021, 04:50 PM #3
Thanks for the reply.
I’m aware that my 2001 doesn’t have LSD which is why I’m asking specifically about installing a true track in those year models with vsc and trac.
Does traction control and vsc interact with the throttle and brakes when the TT locks the axles?
What happens then?
Old 04-05-2021, 01:37 AM #4
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I have no experience, but think of the LSD being a proactive device while Trac is a reactive device. The LSD while lock up in response to driveshaft input, while you will have to wait for the ABS sensors to generate an input to utilize Trac. From that logic, I don't see there being a conflict
Worst case scenario you have to disable Trac.
Old 04-05-2021, 07:43 PM #5
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I expect Trac and a TrueTrac to work in a complementary fashion. Should be a great upgrade.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:07 PM #6
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
That was the experience of a few of the Land Cruiser 100 Series guys that had the 01 and up and well for TrueTracs instead of Full Lockers. They worked together to limit wheelspin, although for some truly hardcore situations, you need to disable TRAC or you won't gen ENOUGH wheelspin to get where you are going.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 01:18 AM #7
anniesball72's Avatar
anniesball72 anniesball72 is offline
anniesball72 is on a distinguished road
Try Trac
Is it worth it.
Thanks
I installed one in my 2002 and it’s the best thing you could do.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
anniesball72 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:14 AM #8
Thanks for the help.
I’m thinking TT in the rear and Andy’s Mod is all I need.
What I don’t want is to hit a patch of ice or water on the highway and have the trac and TT over correcting and sending me in a flat spin to eternity.
Since anniesball72 is alive and well I feel better about the setup. Does it work well in awd on the Highway ab72?
Thanks again.
Old 04-06-2021, 10:18 AM #9
gmcmanus663's Avatar
gmcmanus663 gmcmanus663 is offline
Real Name: Grayson
gmcmanus663 is on a distinguished road
Real Name: Grayson
I'd second that it should be a great upgrade. I have a factory e-locker retrofitted to my 02, and it works well with the vsc system.
1987 4runner dlx (Sold 05/2016)
1998 Ltd 2wd (Sold 07/2016 - 282k)
2002 4runner - Thundercloud Ltd 4wd
gmcmanus663 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:53 AM #10
Thanks again.
They work great together. The TT with TRAC allows almost no wheel spin on pavement. I ended up disabling my VSC/TRAC due to MT swap. On the road in multi mode in snowy conditions the TT is a huge upgrade over TRAC. I wouldn’t look back. No drivability concerns at all.you won’t know it’s there till you need it.
Old 04-06-2021, 02:04 PM #11
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I don't have the TRAC system since mine is 98 but the Trutrac is a great set it and forget it thing to do. Traction on and off-road is greatly improved and is way simpler to do than an e-locker retrofit. I did a trail with my highway rated tires with some friends a few years ago and had less trouble with my highway tires and an LSD that they did with off-road tires and an open diff.
326WHP 347TQ
01-02 , interact , limited , slip , vsc
Eaton E-Locker in 5th Gen Seattle206 5th gen T4Rs 31 05-26-2021 09:48 AM
Eaton Truetrac Front Diff Locker MY06T4R 4th Gen T4Rs 16 12-16-2020 02:16 PM
4th Gen w/ F & R Eaton TrueTrac vs. OEM Open Diff. MarkinWMich Off-Roading 5 12-14-2017 01:23 PM
Eaton Detroit Truetrac PN#913A610 Socal SIKHILUXSURF For Sale: T4R Items 8 02-22-2017 09:29 PM
Installing an Eaton TrueTrac N3BP 4th Gen T4Rs 5 06-20-2014 10:56 PM
