Old 04-05-2021, 12:48 AM #1
jsindorf jsindorf is offline
jsindorf is on a distinguished road
New Shocks and Ride is Horrible
I have a 99 T4R Limited, 4wd, 260,000 miles...
The suspension is basically original, with the exception of new sway bar links at 129,000 and new rear shocks at 167,000.
Last week, I noticed some clanking from the rear suspension when going over a bump. I found the right rear shock was broken (top mount stud was snapped off). I was swamped and a mechanic friend helped me out by replacing the rear shocks for me with new OEM shocks from Toyota.
I'm surprised that the ride is much worse than before the new shocks were installed, and there is much more clanking.
I asked my friend what he thinks it might be -- he said the shocks went in with no problem, but that he had to reuse the bottom bushings since Toyota didn't supply new bushings with the new shocks.
I have ordered new bushings for the bottom mount of the shocks. Is there anything else I should check or replace? This has the original "tall" coil springs. Should those get changed? Should I go OEM or OME?
I really want to fix this... it is really horrible.
Thanks!
Joe Sindorf, Grand Rapids, Michigan
1999 4Runner Limited
260k mi, Auto Trans, 4wd, Locking Rear Diff, v6
jsindorf is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 06:42 AM #2
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
With that kind of mileage you should also check your link bushings. My upper control arms for the rear axle were shot and allowed some play/ popping. I replaced them with the Whiteline bushings and the problem was resolved.
But I would recommend checking the upper and lower arms while you are under there.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 07:51 PM #3
dogbreath650's Avatar
dogbreath650 dogbreath650 is offline
dogbreath650 is on a distinguished road
If the ride got considerably worse with the only change being new shocks then I would think the new shocks are the cause since that's the only variable.
I'd check to see if your mech has the part number from the new shocks to verify they were OEM and spec'd for your vehicle. The clanking may or may not be contributing to the worse ride but if the noise was the same as before and the only thing you did was replace shocks, I'd think it's the shocks.
98 T4R Limited, auto, locker, G1 supercharger
dogbreath650 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 12:39 AM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Those shock tops are tough to get at. I’d make sure your friend put all the appropriate rubbers and washers in the proper positions and that he got it tight enough. I think the shocks come without new top hardware also correct?
If anything is amiss up there you’ll get clanking.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 07:03 AM #5
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Agreed. Those things are such a pain. I bet something ain't right up there in the shock buckets where the sun don't shine.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 08:14 AM #6
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
I went with AM shocks in my GMC Jimmy and the ride sucked.
I would not change from OEM on any 4runner.
4runner shocks can last 400,000 miles
FordF150 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:02 AM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I call total bullshit unless proven otherwise. If they were that durable nobody would stray from them and you would see them being used on plenty other Toyotas, and would be probably one of the most sought after shocks ever produced if they outlast the total lifespan of most vehicles.
Old 04-06-2021, 10:05 AM #8
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
lol....
Standard shocks use oil for their damping, that oil fails with Both age and heat. A completely unused shock will be trash in 10~15 years (unless specially preserved in some climate controlled space), a frequently used shock will be trash in a few years (think endless washboards). Most vehicle fall somewhere in the middle, 5~7 years of acceptable use and about 100k miles.
Not saying a shock can't function for 400k miles, it just needs frequent oil changes. I'm sure that can even be done on the 4runner OEM shocks, but I doubt Anyone, anywhere, has ever bothered. It's simply not cost effective.
At the extreme end, like national level racing, shock oil is refreshed 2 or 3 times a season ~ roughly every 500 miles. I know this because it was my job for awhile, and I'm certified by a few shock manufactures to rebuild their shocks.
The OEM's I pulled off my '99 with 192k miles were beyond dead. There was zero damping going on, exactly as expected.
Brian. is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 11:07 AM #9
nissanh nissanh is offline
The quality of suspension is NOT just Shockabsorbers and coil springs. I recently did a complete suspension bushing replacement all around (except pan-hard bar: Cannot find OEM bushings for it). Used OEM bushings and the ride quality is identical to my newly acquired 21 Tacoma. I did not change the suspension setup (shocks/coil) during this process.
A lot of interior noise is completely gone with the bushing replacement and I feel driving a 21 4runner!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 04-06-2021, 11:24 AM #10
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
As stated previously, when it's to renew worn out suspension components, attention should be placed on ALL components. These includes all bushings, including sway bars and sway bar end links. It's a systematic approach to brings new life to an aging rig.
My daughter and I got done replacing her springs, shocks and sway bar end link bushings. This new to her ride drove like a Cadillac, floaty and severe amount of body pitching when going over speed bumps and driveways. Now, she rides firmer and with control. Still, we have a long way to go.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 11:54 AM #11
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
^^^^^ Check this
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 12:09 AM #12
Thanks Matt,
This is what I was thinking I'd end up doing... new oem shocks, and all of the bushings.
How tough was it to change all of those bushings?
Old 04-10-2021, 01:26 AM #13
turnstylz turnstylz is offline
turnstylz is on a distinguished road
+1 to check rear control arm bushings, esp at 260K. I'm at 270K and just finished replacing all suspension bushings all the way around. If it's a bushing and for suspension, it's been replaced. The rear lower arms were so bad I could literally see through the front and rear of the bushings, i.e. nothing left. I found it didn't make sense to worry about dealing with pressing out old bushings and just ordered all new lower arms, upper arms, and panhard bar, all come with new bushings. The uppers and panhard bushings were still decent, but the lower bushings were trashed.
turnstylz is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 05:14 AM #14
Zoom-a-Loom Zoom-a-Loom is offline
Zoom-a-Loom is on a distinguished road
It's the bushings been through this dilemma and USE OEM bushings
Zoom-a-Loom is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 04:19 PM #15
Ok, so it looks like I am changing out bushings (and other pieces).
Is there a recommended order to doing this -- and for now let's just focus on the rear.
Where should I start?
bottom , bushings , clanking , rear , shocks
Smoother ride? New shocks? Amirocassar 3rd gen T4Rs 8 04-16-2014 01:21 PM
2006 Sport Edition 4wd - ride is horrible ryanmp 4th Gen T4Rs 13 01-09-2013 02:11 PM
FS: OME Comfort Ride Shocks WrexHAmm For Sale: Suspension/Wheels/Tires 2 04-03-2012 04:12 PM
Lift Installed = My horrible ride WrexHAmm 3rd gen T4Rs 30 11-22-2011 10:10 PM
