Old 04-05-2021, 07:13 PM #1
Arn24's Avatar
Arn24 Arn24 is offline
Arn24 is on a distinguished road
Arn24's Avatar
OEM steering rack bushings
Does anyone know if you can even buy the OEM bushings from Toyota? The only PN I've been able to find is for the bushing that goes around the entire rack on the passenger side, PN 4551735010, but I've been unable to find the other two (they're not even shown on the exploded diagram). Looking to replace the poly ones that I put on there (the worst 'upgrade' I've done IMO).
Thanks!
Arn24 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 08:40 PM #2
wao2000 wao2000 is offline
wao2000 is on a distinguished road
Rack bushings
Toyota does not sell service parts for the driver's side rack mounting bushings. I have been told it is because the way it is manufactured "you" can not reinstall the bushings to factory specs. I have seen replacement bushings through other sources but have never tried to install them. We have a couple of 2000 4Runners in the family. On one of them the bushings were worn out and
the boots were cracked / torn and leaking so I just the replaced the rack and the power steering hose line assy. with brand new Toyota parts. It was pricey but I figured after twenty years it doesn't owe me anything and I won't have to mess with it again.
wao2000 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 08:47 PM #3
spartacus's Avatar
spartacus's Avatar
Thanks!
I dont think you can find oem on line .Best bet is to call a local dealer and see if they can get em.
Old 04-05-2021, 09:22 PM #4
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
When I replaced my rack about 18 months ago I installed energy suspension bushings on the new rack. I just dug through a box and found what I believe to be the new OEM bushings that I pressed out of the new rack. The tall one has a part number on it 45522-35040 which doesn't come back to anything available through a dealer, but seems to come up as the steering gear bushing available from China. The shorter one doesn't have any identifying information on it. If you want them, they are yours for the cost of shipping. PM me if you are interested.
Skulking is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:13 PM #5
2001 Limited 285K 2001 Limited 285K is offline
Real Name: Al
2001 Limited 285K will become famous soon enough
Real Name: Al
Had a similar problem back in January so I am under the impression that the answer is "no." The same shop that installed my SafeTCap installed new Moog rack bushings for me. I guess they're okay but TBH I can't tell the difference between the old worn out bushings and the new Moogs. (The "stiff steering" problem that I had on cold mornings was ultimately traced to a lack of Power Steering (ATF) fluid, not the rack bushings.)
2001 Limited 285K is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:20 PM #6
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
Just get the Dorman ones or similar from Rock Auto.
I'm curious what happened with your poly ones however.
I have 2 4Runners at the moment and one has new Dorman and one has new Energy Suspension Poly and they both feel great. Zero NVH and you wouldn't know it's not stock. Very tight steering with no vibrations.
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:26 PM #7
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Not to hijack the thread, but why did you dislike the poly bushings?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 01:41 AM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Thanks!
The long bushing mentioned below is on Amayama for $60, but that's still not a complete set.
Somehow I think your problem is bigger. Poly shouldn't feel that awful. I installed poly bushings because it was the best option short of replacing the rack, which I didn't want to do just yet. I'm pretty anti poly bushing but in this application I really can't see how they are worse than worn originals.
I think the new poly bushings have uncovered another bad part in your suspension. Could be control arm bushings, column play, or even play within the rack. It's hard to fix this without replacing everything, since everything gets worn to piss after 25 years.
Old 04-06-2021, 06:24 AM #9
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
I'd like to know the same thing. Wondering if you may be blaming them for a different problem?
I've had them on two different vehicles and been nothing but satisfied.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 08:19 AM #10
Arn24's Avatar
Arn24's Avatar
Thanks for all the replies!
The current issue with the poly bushings is that they are making noise, I believe. With the exception of tbe UCA bushings, all front suspension components have been replaced within the last 25k miles. But I knew from the day I installed the poly bushings (installed while chasing down what ended up being a tire issue) that I would regret it. Suddenly every bump, crack, or rock in the road was being felt in the steering wheel. I prefer to be isolated from what's going on underneath.
Thanks again!
Old 04-06-2021, 09:04 PM #11
Thanks again!
I hear ya man. I just installed poly everywhere in my front suspension and I could be imagining it but I do feel like some NVH could be present. The ride is hugely improved and I still need to fix my slip joint but I do notice some wheel feedback. Hope you get it sorted out.
01' SR5
Old 04-07-2021, 10:20 PM #12
Arn24's Avatar
Arn24's Avatar
I'll be going back to the OEM rack bushings shortly, I'll let you know how it turns out.
Old 04-08-2021, 05:19 AM #13
Thanks man, I’ll be looking for a report.
01' SR5
bushings , find , oem , put , rack
Steering Rack Bushings Xtremluck 5th gen T4Rs 26 06-25-2020 09:57 PM
Steering rack bushings? Terrapod 5th gen T4Rs 1 06-13-2019 11:37 PM
'98 4Runner Steering Issues: New Rack or ITRE's and Rack Bushings? TheFriZ 3rd gen T4Rs 23 04-25-2019 12:35 AM
Steering rack - Bushings First ?? john1776 3rd gen T4Rs 9 10-23-2015 09:15 PM
inner tie rod, steering rack & bushings Nubie4Runner 3rd gen T4Rs 3 11-19-2010 01:48 AM
