User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 04-06-2021, 05:31 PM #1
jross20's Avatar
jross20 jross20 is offline
Senior Member
jross20 is a jewel in the rough jross20 is a jewel in the rough jross20 is a jewel in the rough
Senior Member
jross20's Avatar
Front Lower Control Arm bolts won't stay torqued
Alright, this is driving me insane. I've had like 3 alignments this year, and none of them hold for more than 5 miles or so.
As far as I am aware, the front lower control arm cam bolts just keep coming loose. As soon as they do everything starts creaking and popping and the alignment blows up. I'm running the whiteline bushings, I've no idea if these are the issue but I've no idea what else would cause it.
One thing I noticed though is that...well, how exactly does one torque the rear camber bolts? (Rear position on the front LCA's). None of my torque wenches can fit into that spot due to the power steering rack being in the way. This got me to thinking...what if none of the shops I've been to have a way to torque it? I guess the only way one could do it would be to use a crows foot? Maybe they are just doing it hand tight, which would explain why they don't last long.
Has anyone else experienced this problem? Really running out of ideas here, I feel like the arms are going to fall off at some point...
jross20 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 06:37 PM #2
tyler.lewis tyler.lewis is offline
Member
tyler.lewis is on a distinguished road
Member
I have not done my lower control arm bushings yet but I did get the same bushings just waiting for a weekend to do it. I used to be alignment tech and we never used to use a torque wrench on suspension stuff while doing an alignment. However with those bolts I would go as tight as possible and then some! Maybe even a hammer at the end of your wrench just to get some more turn on it. Usually when they tighten them the suspension is drooped so maybe tighten them more when it is on the ground. Also, I remember I had a comeback one time on a Dodge Durango. Anyways, going as tight as I could with my wrenches on the UCA wasn’t good enough and the alignment came loose. Using my big 1/2 snap on ratchet solved that issue! I guess what I’m trying to say is that tight is tight and maybe OEM torque specs are not tight enough for some things.
tyler.lewis is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:22 PM #3
photoleif photoleif is offline
Member
Real Name: Leif
photoleif will become famous soon enough
Member
Real Name: Leif
Quote:
did you check out the video about this by Timmy and Sean? see # 28 and #72.
Code:
https://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-t4r-diy-maintenance-repair-modification-videos.html
__________________
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:43 PM #4
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Member
Vansnxtweek will become famous soon enough
Member
Quote:
I appreciate your honesty. I was gonna say before I read your post...ain’t nobody doing alignments using a torque wrench,lol. I’m a bit of a torque freak but I can see where it’s not super necessary there. Good and tight haha.
For the back ones I’m sure they use a box wrench or adjustable and crank the shhhhh out if it.
Seems like an odd issue man. Hard for me to think how the white line bushings could be to blame. I’m gonna have to ponder.
__________________
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 11:44 PM #5
3bears 3bears is offline
Senior Member
Location: north east of Fairbank out there in the frontiers Alaska
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Senior Member
Real Name: 3 Bears
locktite?
__________________
2000 SR-5 Highlander version 4:30's, factory locker , green, bought 6/21
2001 SR-5... bought 11/20..sold 6/21....
2000 SR-5 moded, lifted, e locker, other cool stuff, totaled 10/20
3bears is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 12:33 AM #6
jross20's Avatar
Senior Member
Senior Member
jross20's Avatar
Quote:
Code:
Shoot I've watched a bit of 28 but I wasn't looking for the torque stuff at that time. I will rewatch them, thanks for the idea!
Well I mean I don't think you would do the alignment with the torque wrench, you would just torque it once it's done. I'm in the service manual specifically says 96 ft pounds, I don't think your average alignment tech is going to hit that with some little box end wrench haha.
I actually found a 22 mm 1/2 drive Crow's foot, it's from snap-on. I'm probably going to order it and see if it works.
Quote:
Originally Posted by 3bears View Post
locktite?
Honestly I thought about it, but I don't know if it's a good idea or not
Old 04-07-2021, 01:14 AM #7
Member
Real Name: Leif
Member
Real Name: Leif
i think the rack was kinda loose, for theirs. it isn't a giant extra step after doing the LCAs, to loosen the rack bolts to avoid mangling your inner tie rod boot. another thought along the line of alignment tech practicality, is find a similar size nut elsewhere and torque it to 96 ft lbf with a torque wrench, then loosen and re-tighten with a regular long wrench and remember how it feels to your hand. i just did that for the rear right upper control arm where my torque wrench would not click soon enough to turn the bolt, given all the obstructions. so i just took a SWAG based on how the opposite side felt. i know it's not far off.
__________________
Old 04-07-2021, 11:23 AM #8
19963.4lsr5 19963.4lsr5 is offline
Elite Member
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
Elite Member
96 is about the torque on lug nuts.
19963.4lsr5 is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 11:57 AM #9
spartacus's Avatar
spartacus spartacus is offline
Senior Member
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
Senior Member
spartacus's Avatar
Cam bolt elimination kit with after maket ucas could also be an option.
spartacus is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 08:07 PM #10
jross20's Avatar
Senior Member
Senior Member
jross20's Avatar
Quote:
I did think about that, but then the problem becomes that there are no alignment shops around me that are competent enough to be able to align it using the adjustable upper arm at that point...
Okay so I did finally find a 22mm 1/2 drive crows foot. I'm going to order it and torque the bolts to 96 ft lbs just to see if the noise stops. If that does the trick then the next time I get in an aligjment I'm just going to bring it and either tell him to do it or let me do it as soon as they're done... Haha
Speaking of that, is it worth it to get a torque wrench calibrated or just to get another one? I don't have an expensive one so that's why I'm not sure if it's worth it or not..
Reply
Tags
bolts , front , idea , running , torque
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Over torqued head bolts mendozer 3rd gen T4Rs 10 09-03-2020 02:52 PM
Cut seized cam bolts lower control arm question? hawkcharmer 3rd gen T4Rs 4 09-01-2020 10:59 AM
OEM lower Control arms and cam Bolts part #s Billynath1988 4th Gen T4Rs 7 01-06-2020 10:14 AM
Over torqued lbj bolts dozerfrelich 3rd gen T4Rs 20 10-07-2017 01:05 PM
Lowering Lower Control Arm WITHOUT loosening body bolts? DaveK22 4th Gen T4Rs 4 09-30-2013 10:57 AM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
