Old 04-07-2021, 06:52 PM #1
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Skid Plate Recessed Bolt Issue
I bought my original 2001 SR5 4WD back from the guy I had sold it to 7 years ago. Trying to drop the skid plate and the final 12 mm recessed bolt is starting to strip. I've sprayed it with PB Blaster. Any other suggestions?
I'm trying to change the oil and I know it's possible to do it without dropping it, but eventually it has to come down anyways. Thanks.
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 08:24 PM #2
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
Is the bolt head stripped or the the bolt itself?
If it's the bolt, try and pry it out while turning it.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 04-07-2021, 08:32 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
you know what time it is
Old 04-07-2021, 09:02 PM #4
TX4Running's Avatar
TX4Running's Avatar
The bolt head is stripping. Not quite done but my 12 mm socket won't grab it. I ordered a 12 mm bolt extractor socket.
James
Old 04-07-2021, 09:25 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you're trying to finish today you should be able to pick them up at any Lowes/Home Depot/etc, if you're talking about these suckers. I believe some auto parts stores even carry them, think I saw some in o'reillys. They're a life saver for sure
Old 04-07-2021, 09:30 PM #6
TX4Running's Avatar
TX4Running's Avatar
Yes sir. Ordered a 12 mm of those. Hope it does the trick. Fortunately, I can let the truck sit in my garage for a few days. Will hit it with PB Blaster each day and when the bolt extractor arrives on Saturday, I will try to get it out. Thanks.
James
Old 04-08-2021, 05:21 AM #7
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Don’t underestimate the power of vise grips if the socket doesn’t work. I’d get a screwdriver in there to pry like someone said to help it and get the vise grips as tight as possible and she should come on out. Good luck, ain’t nothing more aggravating than one stinking bolt taking up all your time. Those skid plate bolts drive me insane. I’ve had my battles with them for sure.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 05:22 AM #8
After I typed this I saw you said “recessed”
My bad, vise grips ain’t gonna work there. Fingers crossed for the socket!
01' SR5
Old 04-08-2021, 08:43 AM #9
TX4Running's Avatar
TX4Running's Avatar
No problem. Anyone know part numbers to replace the skid plate bolts? Or size to buy some new ones? Thanks.
James
Old 04-08-2021, 08:49 AM #10
These look like it to me.
GENUINE TOYOTA UNDER COVER SPLASH SHIELD SKID PLATE BOLT 90080-11373 | eBay
Was trying to find the skid plate/bolts on the OEM parts diagram but still searching.
Finally found the skid plate in the diagram but it doesn't show the bolts, haha. Radiator Support for 2001 Toyota 4Runner | Camelback Toyota Parts
I have a strong feeling those bolts in the ebay auction are it.
P/N 90080-11373
You could just go to your local hardware store and take a good bolt and match it up. I'd replace them all and put anti-seize on them when you install them. They either have to be 8 or 10mm thread bolts.
01' SR5
Old 04-08-2021, 08:55 AM #11
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I believe the skid plate bolts are M8-1.25 x 25mm flange bolts. You can get them in stainless steel. And as @Vansnxtweek said, coat them with some anti-seize.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 04:29 PM #12
Also, always use 6-point sockets when working on a vehicle... Though likely the bolt was damaged before you got to it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-08-2021, 06:27 PM #13
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Yep - I upgrade any fastener I can with a higher grade/stronger material. There are lotsa online bolt distros with every damn thing you can imagine (if your local HW store or big box doesn't have it). My last order came from the boltdepot.com because high-grade metric bolts and nuts in a 1.25 TP aren't always easy to find on the fly.
Also, it's a good idea to hit a pick-n-pull for a vast assortment of Japanese fasteners for your Magic Bucket. You do have a Magic Bucket,.......right? LOL
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 04-10-2021, 01:45 AM #14
turnstylz turnstylz is offline
turnstylz is on a distinguished road
For those that stumble on this tread and want oem, can confirm original part number 90119-08A33, replaced by 90080-11373
turnstylz is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 05:10 AM #15
Zoom-a-Loom Zoom-a-Loom is offline
Zoom-a-Loom is on a distinguished road
I use allen head stainless, never a problem & can use a vice grip on the head if needed
Zoom-a-Loom is offline   Reply With QuoteReply With Quote
blaster , bolt , plate , recessed , skid
OEM Skid Plate Bolt Size _ExpeditionMan Classic T4Rs 7 12-22-2015 02:41 PM
'03 Skid Plate Bolt bradentyrer 4th Gen T4Rs 7 01-14-2013 01:43 PM
Diff drop bolt question - Skid plate issue 5280nrg 3rd gen T4Rs 7 10-13-2012 05:25 PM
bolt sizes on skid plate ohio4runner4x4 3rd gen T4Rs 1 08-03-2005 06:52 PM
Had to Tap & Die a Skid Plate Bolt Bluto Problems & Warranty Issues 20 03-04-2005 11:39 AM
