04-07-2021, 06:52 PM
Skid Plate Recessed Bolt Issue
I bought my original 2001 SR5 4WD back from the guy I had sold it to 7 years ago. Trying to drop the skid plate and the final 12 mm recessed bolt is starting to strip. I've sprayed it with PB Blaster. Any other suggestions?
I'm trying to change the oil and I know it's possible to do it without dropping it, but eventually it has to come down anyways. Thanks.
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
04-07-2021, 08:24 PM
Is the bolt head stripped or the the bolt itself?
If it's the bolt, try and pry it out while turning it.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
04-07-2021, 08:32 PM
Real Name: Devan
Real Name: Devan
04-07-2021, 09:02 PM
The bolt head is stripping. Not quite done but my 12 mm socket won't grab it. I ordered a 12 mm bolt extractor socket.
James
04-07-2021, 09:25 PM
Real Name: Devan
Real Name: Devan
If you're trying to finish today you should be able to pick them up at any Lowes/Home Depot/etc, if you're talking about these suckers. I believe some auto parts stores even carry them, think I saw some in o'reillys. They're a life saver for sure
04-07-2021, 09:30 PM
Yes sir. Ordered a 12 mm of those. Hope it does the trick. Fortunately, I can let the truck sit in my garage for a few days. Will hit it with PB Blaster each day and when the bolt extractor arrives on Saturday, I will try to get it out. Thanks.
James
04-08-2021, 05:21 AM
Don’t underestimate the power of vise grips if the socket doesn’t work. I’d get a screwdriver in there to pry like someone said to help it and get the vise grips as tight as possible and she should come on out. Good luck, ain’t nothing more aggravating than one stinking bolt taking up all your time. Those skid plate bolts drive me insane. I’ve had my battles with them for sure.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
04-08-2021, 05:22 AM
After I typed this I saw you said “recessed”
My bad, vise grips ain’t gonna work there. Fingers crossed for the socket!
01' SR5
04-08-2021, 08:43 AM
No problem. Anyone know part numbers to replace the skid plate bolts? Or size to buy some new ones? Thanks.
James
04-08-2021, 08:55 AM
I believe the skid plate bolts are M8-1.25 x 25mm flange bolts. You can get them in stainless steel. And as
@ Vansnxtweek
said, coat them with some anti-seize.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
04-08-2021, 04:29 PM
Also, always use 6-point sockets when working on a vehicle... Though likely the bolt was damaged before you got to it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-08-2021, 06:27 PM
Real Name: Blair
Real Name: Blair
@ Vansnxtweek
Yep - I upgrade any fastener I can with a higher grade/stronger material. There are lotsa online bolt distros with every damn thing you can imagine (if your local HW store or big box doesn't have it). My last order came from the boltdepot.com because high-grade metric bolts and nuts in a 1.25 TP aren't always easy to find on the fly.
Also, it's a good idea to hit a pick-n-pull for a vast assortment of Japanese fasteners for your Magic Bucket. You do have a Magic Bucket,.......right? LOL
04-10-2021, 01:45 AM
For those that stumble on this tread and want oem, can confirm original part number 90119-08A33, replaced by 90080-11373
04-10-2021, 05:10 AM
I use allen head stainless, never a problem & can use a vice grip on the head if needed
