Old 04-07-2021, 09:03 PM #1
cfb2702 cfb2702 is offline
Real Name: Bud
cfb2702 is on a distinguished road
Real Name: Bud
Weird brake issue, 3rd gen
A couple of weeks ago, while backing up in my 3rd gen, I notice the brake pedal had a significant amount of resistance, while lacking stopping power. It went away, but resurfaced now in both reverse and drive. Checked fluid levels and all are in normal operating range. When applying pressure to brakes, there is a significant amount of resistance, followed by a gradual release of the backpressure, then the brakes finally begin to apply.
Checked vacuum hose to brake booster and found no apparent leaks. Is the brake booster suspect, or should I be looking elsewhere? It's a 97 limited 4WD with 270k miles. Thanks in advance for any sage advice.
cfb2702 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 06:48 AM #2
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek is on a distinguished road
I don't have any personal experience with this issue but I have tried to chase down other brake issues in the past and its very aggravating.
This thread may get you started...
Brake pedal hard to push down
01' SR5
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 08:13 AM #3
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
Sounds like the brake booster check valve. I had the same thing happen to me and it was the check valve. 5 minute repair and 20ish bucks for the part.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 12:50 PM #4
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw will become famous soon enough G_Raw will become famous soon enough
G_Raw's Avatar
This...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 02:07 PM #5
FD7683 FD7683 is offline
FD7683 will become famous soon enough
Very true for me too. I have done a lot to chase the low brake pedal issue and it is still low lol.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 04-08-2021, 02:22 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Originally Posted by FD7683 View Post
...I have done a lot to chase the low brake pedal issue and it is still low lol.
I believe that is a Feature of this trucks! All vehicles are different, especially these, haha.
Mine always has been 'low', yet if depressed enough it will grab on enough to actuate the antilock system, so i know it works as intended.
2001 Limited 4WD - 331+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
amount , booster , brake , checked , resistance
Weird brake vsc trac and warning chime issue OC2003 4th Gen T4Rs 4 02-17-2019 05:47 PM
Weird Brake Issue After Caliper and Pad Change inscarguy 4th Gen T4Rs 24 09-01-2017 12:57 PM
weird brake issue round 2 Frontline 4th Gen T4Rs 1 01-12-2017 11:12 PM
2008 sr5 4wd weird brake issue Civiceg94 4th Gen T4Rs 23 06-23-2016 10:00 AM
Weird Brake Light Issue metallicarox Classic T4Rs 1 03-16-2009 03:37 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
