Old 04-08-2021, 12:32 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Tundra Brake Upgrade
Morning!
I did the tundra brake upgrade using the 199mm/13WE pads/rotors. just noticed that the clip on my driver side didn't look right. pulled the other tire and it looked the same. not sure what the "spring" is called or the part number. can anyone help?
if you look at this video at about 1:15 the guy is removing what I'm referring to. https://www.youtube.com/watch?v=0qS1EaoQQhY&feature=youtu.be
here's a picture of what it looked like when I found mine:
Tundra Brake Upgrade-img_20210407_115223-jpg
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 06:16 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by psea17 View Post
Morning!
Check out the video at 11.59 mark. the guy puts the spring in correctly.
https://www.youtube.com/watch?v=sYNTePbJilo&feature=youtu.be
Old 04-08-2021, 07:32 PM #3
thanks. the video i posted showed it as well. just need to know what the part number is.
Manual Transmission
Old 04-09-2021, 10:48 AM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
looks like 47748A or some more modernized variant of it. i'm still using
Code:
http://japan-parts.eu/toyota/us/1999/4runner/vzn185l-gkmgka/3_671460_007_/powertrain-chassis/4705_front-disc-brake-caliper-dust-cover
for lookups, but they show the old-style PN. go through the filter to specify your model-year and frame code, or use your VIN. not for this part, but i've often found that if you plug in the old-style PN into amazon, you'll get results that show the full two-part PN that toyota switched to.
another edit: 47748-35010 found on
Code:
https://parts.toyota.com/p/Toyota_1999_4Runner-SR-5-34L-MT/Disc-Brake-Anti-Rattle-Clip-Front/63130831/4774835010.html
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 10:52 AM #5
spartacus's Avatar
spartacus's Avatar
Its called Tundra anti rattle spring
Advance Auto Parts - Down for Maintenance
Old 04-09-2021, 11:05 AM #6
spartacus's Avatar
spartacus's Avatar
https://shop.advanceautoparts.com/fi...-rattle-spring
Toyota part number
Disc Brake Anti-Rattle Clip
Part Number: 477480C010
Supersession(s): 47748-0C010
Old 04-11-2021, 02:30 PM #7
Thanks everyone. Got it!
Manual Transmission
brake , looked , pads/rotors , tundra , upgrade
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
