gamefreakgc, mtbtim
Old 04-09-2021, 01:24 AM #31
alphyn's Avatar
alphyn alphyn is offline
alphyn will become famous soon enough
alphyn's Avatar
Originally Posted by Kanoe View Post
This one won’t break the budget - get rid of that squeaky clutch spring.
Use a big flat screwdriver to pop that old one out and toss it. Put in a linear spring. It’ll take 10 minutes and cost from free up to a couple dollars.
Mine has been done for years and no regrets.
Finally someone else who can empathize with my pain! I've seen a few different fixes for it. Adding brackets, changing out springs, etc. I've owned manuals my entire life and it seems like a ridiculous oversight by Toyota not engineering a better solution. More of a rant than anything else. Nice to see someone else here who likes to row their own canoe.
1999 4runner Highlander (Manual)
1993 Nissan 300zx Twin Turbo
alphyn is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 10:11 AM #32
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
i ripped mine out as well and put in a small coil spring. i got one pack from HD, and that turned out to be too firm, so i went to napa and got one that wasn't so heavy-duty and it works much better. i then wanted the bushing to stop its wretched groaning, so i ordered some new ones and upon attempting to install them, realized that they were the right *kind* of bushing but too small and simply were not going to work, so i cleaned and greased the old and that's been just fine and it's quiet. the spring gets strummed a bit like opening an old screen door, but oh well. it's far better than the alarming clatter and poor return.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 01:07 PM #33
alphyn's Avatar
alphyn's Avatar
Any chance you remember what length spring worked the best?
The spring gets strummed a bit like opening an old screen door, but oh well. it's far better than the alarming clatter and poor return.
I'm going to call out a great analogy when I see it. I can imagine perfectly how it would sound. Memories of my grandparents house in Montana came roaring back. Thanks for taking me back in time a bit and putting a smile on my face.
Old 04-09-2021, 03:42 PM #34
Real Name: Leif
Real Name: Leif
hehe no problem. that's exactly the place i heard that same spring strumming: grandparents' house, minnesota, with mosquitos streaming through the door as younger cousins stood there holding it open for no reason, trying to process why we were yelling at them to close the door.
in terms of length, the spring i ended up with is about 3-1/2" long and about 3/8" coil diameter. i wish i had the PN but i do recall they had a couple available as kind of off-the-shelf all-purpose springs, and this one had the lower rating (as in pounds to pull). the ones i got from home despot were 40 lb, and that is way too much. if you get up under the dash with a good floody light, you can probably spot a body panel that has a convenient hole stamped in it. i used that, but its alignment with the pin on the pedal isn't ideal, which is why the strumming. it grazes another bit of body panel. you can measure the distance from that hole to the pin. the first springs (the HD ones) i got were shorter and stout, and i ended up making a linkage out of some round mild steel rod. the second (current) spring was a little longer, which is good, and i could shorten the linkage quite a bit.
if you go to napa or a hardware store to find a spring, one test of fitness for purpose is that you can hold it at the end and bend it somewhat with one finger. if it's too stiff to do that, it's too stiff for this use case. if it's really bendy and you can easily bend it 90°, that's too soft.
my wife drove the 4R today to work, or i'd have taken a photo of it for you. i can get you one later if you'd like.
here's the first spring i tried (home depot purchase), the one that was too stout.
0 Upgrade Budget - What to do?-too-much-spring-jpg
Old 04-09-2021, 09:37 PM #35
alphyn's Avatar
alphyn's Avatar
Perfect! Again, I remember reading through posts before talking about grabbing random springs and shovin' up in there only to have to try a couple before it worked out. I think that's how babies are made, not sure. Anyway, this is the first time I recall anyone providing more constructive advice than trial and error. Really appreciate it! I'm on a roll solving long tolerated 4Runner probs. Without you and the rest of the folks here, I'd be in a tough spot. Thanks again!
Annnnnnnnd after I get this sorted I am going to tackle deferred maintenance on my 300zx. Pray for my soul.
Old 04-09-2021, 09:53 PM #36
Real Name: Leif
Real Name: Leif
glad to help. here's the new spring in place. this entirely replaces the U-shaped torsion bar spring that's normally in there; follow other instructions for full removal of it. might add some fashionable duct tape like this to keep the strumming to a dull roar. you can see the difference in wire diameter compared to the first one. this is ~half of the first try. see what your local parts store has. this one was long enough that i could take out the hook i used for the other one. i had to remind myself all it has to do is pull the pedal back up to the up position.
0 Upgrade Budget - What to do?-new-spring-jpg
fuel , items , maintenance , upgrades , vehicle
Budget radio upgrade with JBL benztech82 4th Gen T4Rs 3 05-21-2020 11:35 PM
Budget Switch Pros setup and other budget options for switching/lighting? trailtruck Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-04-2019 07:44 PM
HELP: 2003-2005 Projector/HID Upgrade (NOT '06+ upgrade) VT_Kook 4th Gen T4Rs 6 10-10-2017 04:58 PM
WTB/WTT: TX 99-02 4WD 3rd gen $8k budget DDeezenuts For Sale: Vehicles 80 03-27-2017 01:38 AM
If you had a budget? kyle_uran General Discussions 9 12-09-2015 12:29 PM
