Old 04-08-2021, 10:44 PM #1
HNTMUP HNTMUP is offline
HNTMUP is an unknown quantity at this point
2002 warning lights
Blew out a brake line and lost all pressure. (Fortunately I wasn’t in the road). Pretty much lit up the warning lights and I’m guessing triggered a lot of codes. Had all the lines replaced and brakes are better than they have been in a long time. Only problem is it won’t go into 4wd when I press the button. I can put it into low via the lever so I know it’s not the transmission.
Question: if I have a tech clear all of the codes I’m guessing all of the lights will go turn off but will I be able to get into 4wd H?
Thank you,
JDG
HNTMUP is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 05:52 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Read the codes Before clearing them. There may be a clue as to why it won't go into 4hi.
Now clearing them may or may not solve the issue.
A wire could have accidently been bumped/loosened during the brake line replacement or it is just a coincidence the 4x4 developed an issue at the same time as the brakes???
Old 04-09-2021, 10:15 AM #3
It all happened when the brakes went flat. Zero pressure in the lines. This is a current view of my dash.
Old 04-09-2021, 11:33 AM #4
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Definitely pull codes with an OBDII reader before clearing, but that combination of lights may not actually show any OBDII codes. ABS issues don't show up as OBDII codes, instead you need to jumper the ABS diagnostic port on the engine to read the ABS codes. You can find write ups and videos on how to do that pretty quickly with a bit of searching.
Skulking is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 11:46 AM #5
spartacus's Avatar
spartacus's Avatar
Thank you,
JDG
TRAC VSC and ABS lights on
Old 04-09-2021, 12:24 PM #6
Thanks fellows. I just use this truck for work on our property in northern MI. My primary interest is getting the 4H engaged.
Do you think the problems with the VSC is over-riding the ability to electronically engage 4H?
4wd , it’s , lights , put , warning
Warning lights Blackstallion 3rd gen T4Rs 3 08-18-2014 12:08 AM
Warning lights psu1987 4th Gen T4Rs 1 05-30-2014 07:59 PM
88 warning lights? suntinez Classic T4Rs 6 08-19-2011 10:42 AM
Need Help...Warning lights just on??? DRich43 4th Gen T4Rs 9 12-14-2009 11:21 AM
Warning Lights???? Aero Classic T4Rs 4 07-25-2005 07:34 PM
