Old 04-13-2021, 08:35 AM #16
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
When I had my engine out (donor motor was on a stand) I replaced the rear main seal which was bone dry. Now, my new OEM rear main seals leaks. I'm not exactly sure how I messed it up but I did so I'm definitely in the camp of "if it's not broken, don't fix it". At least for the rear main seal.
I did replace a ton of other things while the engine was out.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 08:38 AM #17
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Pulling heads would be the last thing on my list during an engine removal unless something is wrong, or you are really good at checking heads and have unlimited funds and time, and if thats the case you might aswell do rings while you're at it, and replace every frost plug. Heads, valves, and knock sensor wire harness can all be done when they become a problem in the engine bay.
Rear main and oil pan is not accessible unless engine is out and will cost you 1 seal, some permatex ultra grey and about an hour if you clean it up well.
Malcolm99 is offline   Reply With QuoteReply With Quote
engine , hand , pulled , rabbit , transmission
Has anyone pulled V6 engine from 4th Gen 4Runner? ysrsquid Problems & Warranty Issues 123 07-07-2020 01:37 PM
Pulled engine won't start mforce 3rd gen T4Rs 51 06-13-2019 06:23 PM
FS: 5VZ-FE Engine - $600 and 2WD Transmission - $300 gamefreakgc For Sale: T4R Items 1 10-11-2016 09:57 PM
5VZ-FE V6 Engine and Transmission absalom For Sale: T4R Items 3 04-07-2015 04:17 PM
Engine/transmission rebuild kit gmata 3rd gen T4Rs 10 11-08-2011 09:07 PM
