Old 04-20-2021, 09:47 AM #46
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
Has anyone looked into running 4th gen / FJ front suspension to solve the ball joint issue? Its an idea ive been playing with and have a friend who will be designing his own long travel for his FJ so hopefully he will send me some dimensions.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 10:48 AM #47
luiszo luiszo is offline
luiszo is on a distinguished road
Originally Posted by Bad Luck View Post
04005-02235 contains both left and right ball joints and cotter pins. You will need to order two castle nuts 90171-A0005 and eight lower ball joint bolts 90119-10933 (37 ft/lbs). The ones you listed from McGeorge Toyota are OEM just priced separately.
Thank you Bad Luck!!!
Ordering today.
luiszo is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 02:29 PM #48
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Originally Posted by FD7683 View Post
Thanks, I really needed this part #!
This was for the 96-00 balljoint, BTW. It did not have the dust boots.
Personally I'd go for the older style balljoint and bolts with the 59 ft-lbf spec anyway.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 03:13 PM #49
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
1996-2002 have the same ball joint. The dust cover is a separate part from the ball joint. I think you are referring to the lower ball joint bolts. Old style bolts with flange not compatible with dust boots 90080-10066 torque to 59 ft/lb. New style bolts with washer for use with dust boots 90119-10933 torque to 37 ft/lb.
Old 04-20-2021, 03:31 PM #50
texadelphia texadelphia is offline
texadelphia will become famous soon enough
This thread is giving me anxiety about my 226k mile lbjs.
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 10:29 PM #51
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I have a 2000, i'm sure it would fit fine with the new bolts thrown in. Living in Ohio my main worry would be the soft bolts under it.
Mine are also the OEM's at 226k too, ouch.
2000 4Runner Limited 4x4 V6
lbj , lift , replaced , surprised , wheel
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Tie Rod & Lower ball joint DannyLlama 5th gen T4Rs 26 10-29-2016 11:45 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Lower ball joint nissanh 3rd gen T4Rs 6 11-09-2013 09:16 PM
short lived fun mspa Classic T4Rs 17 10-29-2007 11:18 PM
