Old 06-22-2021, 01:15 PM #46
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
Originally Posted by 906-Runner View Post
There has been a development, I disconnected the radio and tapped into the power outlets and it works so that’s good. But the interesting thing is now my clock and interior lights work, but only when the headlights are on. As soon as the turn the headlights off, the interior lights no longer work and the clock turns off, resetting to 1:00. Any one got any ideas? I’m getting good voltage everywhere
from what you're describing, it sounds like there was some janky wiring done in there with bridging circuits or tapping into circuits one shouldn't use for power. if the headlight circuit is being used for those other devices, i believe it's likely someone got in there and crossed some wires. i suppose it's remotely possible that there could be something honked up in your fusebox, but i think that's far-fetched.
to your knowledge has there ever been any work done in there? i'm thinking aftermarket stereo for instance, where someone's in search of +12v and whatever they find, they vampire-tap into and just go with it. i know this because that's what i did in my truck when i first was messing about. i've since rewired in an entirely different way using an auxiliary battery.
so, i would definitely be looking very hard at any custom or loose wiring in the dash, and attempting to determine if it's vampired to any leads it shouldn't be. i would also just have a quick look in the fusebox (the one under the hood) just to verify that no obvious cross-circuit bridging is there.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
dim , dome , light , plug , radio
Driver door light / dome light problem LRT 5th gen T4Rs 8 01-02-2020 10:25 PM
Overhead dome light attachment question rwh963 4th Gen T4Rs 7 10-15-2018 03:36 PM
personal light/front dome light bigred528 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 11-01-2010 01:30 PM
Dome light question 1998 ltd DieselPower 3rd gen T4Rs 3 09-23-2010 08:42 PM
Help: Dome Light Question. RapidRunner 4th Gen T4Rs 3 12-06-2006 08:27 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
