03-18-2018, 03:44 PM
Real Name: Jordan
Real Name: Jordan
Flat Towing 3rd Gen -- What's Needed?
I've seen several other threads posted regarding a similar topic, but the posts always seem to end before a conclusive answer is posted.
In any case, we'll most likely be scooping up a 3rd gen to tow behind our Sprinter (assuming all goes well in this thread).
It'll be an automatic 4runner. What all is needed to flat tow these? Drive shaft disconnect? Tips?
03-18-2018, 06:12 PM
Steering unlocked, trans and tcase in neutral.
03-18-2018, 08:24 PM
Manual says transmission will be damaged if towing with rear wheels on ground.
Disconnect driveshaft, transmission in neutral and in H2.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
03-18-2018, 09:10 PM
Real Name: Instagram: briansd_97r
Nope
I had to google Flat Towing but if I have it right then NO YOU CANNOT SAFELY DO THIS.
In the owners manual for 4Runners with an automatic transmission it very clearly says do not tow with the rear wheels moving under any circumstances.
I had to do it myself (via uhaul 2 wheel dolly) to get out of Death Valley and I am very lucky from what I hear that there seems to be no long term damage.
When I towed out I put it in N, transfer in N and 2WD. Thats the best I could do but even then others told me I should have dropped the driveshaft.
The issue stems from the fact that with an auto trans whenever the rear wheels are moving the transmission is still moving but with the vehicle not powered on it may become damaged.
The manual has a clear picture that indicates don't tow with rear wheels on pavement and spinning. I guess maybe you could lock the steering wheel and do a reverse tow with the front wheel on the ground.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
03-18-2018, 09:59 PM
Real Name: Keith
Real Name: Keith
From my PDF of the 1997 owner's manual:
03-18-2018, 10:09 PM
Anyone know what gets damaged in the transmission if towed with the rear wheels on the ground?
I actually towed my '01 like that, and it fixed the trans
That's why I'm asking.
03-18-2018, 10:14 PM
If you disconnect All drive shafts. You should be good. Or put tcase in neutral. Right ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
Lol well I towed mine too -- about 300 miles.
You've got a beautiful rig though and I wouldn't take the chance.
Realistically of the options pictured, B seems the most valid one. I don't think there is a 2-wheel dolly that is highway legal, maybe in Japan...
Or .... as mentioned before and below disconnect the rear driveshaft and tow it with the rear wheels down.
03-19-2018, 12:43 AM
Real Name: Jordan
Real Name: Jordan
I'm thinking I'll be fine with rear driveshaft disconnected.
Front axles will turn, but front diff has its own oil reservoir in clam shell. I don't think spinning front wheels turns anything in transfer case when it's in 2wd mode.
Right?
03-19-2018, 01:01 AM
Yes you should be fine with the rear driveshaft disconnected.
03-19-2018, 08:46 AM
I have always thought it strange when I see an expensive RV towing an expensive car behind it, just rolling along behind, adding up miles on the odometer. With all the money invested, why not just add a couple of grand and get a used, small flatbed so your tow- behind car doesn’t rack up all those miles? A friend of mine has well over 100,000 on a very nice newish Jeep SUV, and has probably actually driven it only 20,000 miles. Not being an RV’er am I missing something? And I’m not sure an 80 year old couple pulling a new Honda Accord is disconnecting driveshafts, etc.
03-19-2018, 09:22 AM
So wait, now I'm kinda confused.
@ BrianSD_42
If 4runner is RWD when not in 4WD, and thus can't tow with rear wheels on ground (unless rear DS disconnected), does that mean in a FWD car like my automatic tranny Civic, you shouldn't tow with the front wheels on ground for same reason? (And you can't 'disconnect' front DS, there is no DS, lol its a transaxle with CV's).
03-19-2018, 09:45 AM
I think it means you should check the Civic's owners manual.
03-19-2018, 09:48 AM
Real Name: Jordan
Real Name: Jordan
I have a 5,000 weight limit, and a trailer that could handle a 3rd gen would put me over that limit.
I'm not worried about miles on a $3,000 4runner.
03-19-2018, 11:16 AM
Right?
Disconnect driveshaft, transmission in neutral and transfer case in H2 it will be ok.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Flat towing
KidVermicious |
Classic T4Rs |
26 |
06-02-2018 02:07 AM |
Flat Towing
USMCYota |
4th Gen T4Rs |
6 |
06-13-2012 01:21 PM |
Flat Towing an 07
Mtnbiker72 |
4th Gen T4Rs |
0 |
11-18-2011 03:06 AM |
Flat towing
SDHNTR |
Classic T4Rs |
14 |
04-07-2011 12:02 AM |
Flat towing
TazH |
General Discussions |
4 |
12-04-2010 06:10 PM |
