Old 04-10-2021, 02:03 PM #1
scottndsky scottndsky is offline
scottndsky is on a distinguished road
TBU Upgrade Problem with Rotor Diameter
Need some help here! I'm in the middle of a TBU on my 2001 SR5 that originally came with standard 15" steelies and calipers stamped S12WE. Everything I've read seemed to indicate that the Tundra rotors are thicker, but the same diameter. Not in my case!
I popped the new rotor on and immediately noticed them dragging against the dust shield. On closer inspection the Tundra rotors are much bigger (317mm vs 297mm). I dedicated the weekend to this job. Now I'm dead in the water. The new S13WE calipers will bolt onto the spindle, and they clear the rotor. The only problem I'm seeing is the interference with the dust shield.
Do I have to order new dust shields to fit these Tundra rotors? Do I need to press the hubs out to get new dust shields on?
Feeling F'd right now. Any help would be appreciated.
Thanks,
Scott
TBU Upgrade Problem with Rotor Diameter-20210410_101047_resized-jpg  TBU Upgrade Problem with Rotor Diameter-20210410_101700_resized-jpg  TBU Upgrade Problem with Rotor Diameter-20210410_101739_resized-jpg  TBU Upgrade Problem with Rotor Diameter-20210410_101712_resized-jpg  TBU Upgrade Problem with Rotor Diameter-20210410_105531_resized-jpg
scottndsky is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 02:12 PM #2
99problems's Avatar
99problems 99problems is offline
99problems is on a distinguished road
99problems's Avatar
You have to trim the dust shield. Not a major issue. BigFishAllDay did a fantastic write-up with pictures that covers this (about 1/2 way down page 1) here: Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors
Bilstein 5100 shocks and OME 2881/2906 springs; Tundra brake upgrade w/ SS lines front & rear; Big-3 electrical upgrade; Airaid intake.
99problems is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 02:13 PM #3
ruudemann ruudemann is offline
ruudemann is on a distinguished road
Cutting the shield will be your easiest way of fixing your issue. If you have a welder you could buy new shields, cut em and spot weld em back together. Gotta press the bearing to remove the shield
ruudemann is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 10:15 PM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
if you want to watch it, check out @mtbtim 's video:
https://www.youtube.com/watch?v=P8zy-j4UBUo
when i did mine, i trimmed in place. i found trimming to be easy but loud as F.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 07:35 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Cutting the dust shield is required no matter what size rims you have. Either get some tin snips, heavy duty shears or an angle grinder and cut/bzzz'd it off so it clears.
326WHP 347TQ
dust , rotor , rotors , tbu , tundra
4th gen rear rotor problem Angstrom 4th Gen T4Rs 11 02-25-2018 05:10 PM
3rd gen 4runner- OEM rotor part # for 199mm brake upgrade? hawkcharmer 3rd gen T4Rs 3 05-05-2015 08:27 PM
Brake/Rotor Upgrade - HELP LillyWhite 2006 4th Gen T4Rs 1 11-18-2011 10:35 AM
Help with rotor problem jsnrhe 4th Gen T4Rs 3 10-02-2011 12:28 PM
Front rotor problem kayak99 Problems & Warranty Issues 12 03-30-2007 08:32 PM
