Old 04-13-2021, 01:00 PM #1
CWccw CWccw is offline
CWccw is on a distinguished road
Ac compressor going out, what should I replace while I'm in there...
The ac compressor is freezing up and am wondering what I should replace since the system will be apart.
98 5vz 291k
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 02:13 PM #2
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I replaced my entire A/C system last year. It wasn't working so I figured i'd just replace everything that way I wouldn't have to worry about replacing anything on it for a while. I also flushed all the lines and got new orings. Works great now. If you don't want to replace everything i'd at least replace the drier as that should be replaced if you're opening the system. This thread helped a lot: DIY Complete AC Replacement on 2000 T4R Limited
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 03:13 PM #3
azrex azrex is offline
azrex is on a distinguished road
If it's a keeper, replace the compressor, drier, expansion valve, evaporator (if it shows signs of leaking or can't be cleaned of debris), the condenser if it has signs of leaking or is beat up from rocks and replace all the o-rings while you've got it apart.
azrex is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 03:51 PM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
there's those little clips for the A/C lines that are kinda brittle; perhaps see if they're available to replace. also because you may choose to remove the PS reservoir for better access, this could be a good time to clean it out (see video by @mtbtim ). also change out three belts if they haven't been changed recently. if you're going all out like @azrex suggests, great time to clean out bugs and crap from the condenser and radiator.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 05:23 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
98 5vz 291k
What do you mean freezing up? As in locking up?
Old 04-14-2021, 12:22 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
there is also an AC belt idler pulley that can get noisy. Add that to your list.
5vz , compressor , replace , system , wondering
Getting Ready to Replace A/C Compressor hyken 3rd gen T4Rs 55 06-02-2021 10:18 AM
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 31 10-01-2020 12:45 PM
A/C Compressor Leak - Replace vs Repair? Charles4x4 Classic T4Rs 0 04-14-2017 11:08 PM
a/c compressor "screech" wen compressor engages or cycles? xspsi6 3rd gen T4Rs 9 06-14-2014 04:51 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
