Old 04-15-2021, 09:43 AM #1
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Trans temps
Hey I recently got an ultragauge and have been monitoring the trans temps. First off I’m wondering what’s a normal operating range for trans temps and engine temps? My engine temps usually don’t go higher than 190 but at one point on a hill climb they were up around 202 for a second. The trans temps are all over the place but sometimes with overdrive on and when I’m engaged in 4th gear the temps would always rise and once got up to 215 before I noticed and let off. So I’m wondering why do the temps increase so much when it’s in 4th gear and they drop as soon as it downshifts into 3rd or up shifts into 5th. And what’s the point I need to worry on trans temps?
TW44LR is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:02 AM #2
Novashards Novashards is offline
Novashards will become famous soon enough
Its all about the friction.
When the torque converter is locked up, there isn't extra friction. 3rd is locked up. 4th is locked up until you ask for more acceleration then it can unlock in 4th and start generating that extra friction, you can see when this happens because the rpms will rise slightly but not as much as they would if you had downshifted. Press the pedal a bit more or disable overdrive and it will downshift to 3rd and lock up again and you will see the transmission temp immediately start to drop to normal.
Novashards is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:04 AM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
LOTS of answers to this in these forums:
site:toyota-4Runner.org/3rd-gen-t4rs/ transmission temps - Google Search
Brian. is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:11 AM #4
Trans temps
Your 5th gear is actually the torque converter locking up in 4th. When the torque converter locks up or the engine RPMs are above its stall speed (somewhere approaching 3000) it’s hardly making any heat.
Old 04-15-2021, 10:39 AM #5
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Your engine temps going up to 202 are nothing to be concerned about.
190 is "normal" but it could be at 202 for a long time and still be fine.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 11:39 AM #6
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Trans temps
My Toyota Factory Service Manual (year 2000) shows the normal operating temperature ranges as:
- 158-176 F for ATF
- 176-203 F for Coolant
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 12:26 PM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
- 158-176 F for ATF
Huh, my UG recently reported 249(!) degrees trans temp on a loooong, slow desert dirt climb and the A/T Oil Temp light didn't even come on (it works at start-up). My trans temp is all over the place and often runs hotter with OD on than off. I can be cruising on the freeway at 70 at approx 2K engine RPM , turn OD off and drop the tranny temp 10 degrees while running at 3k engine RPM (not saying they are related - just saying). My Trans oil is still red, smells good, and is smooth to the touch. I will be doing the filter and a fluid drain/replace soon anyway.
Old 04-15-2021, 12:29 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
To be honest, you are probably better off not monitoring your temperatures. Everything you've stated is normal operation for a used vehicle with 150K+ miles on it. I think you'll drive happier NOT knowing what the temps are.
The engine temperature gauge will start to rise past halfway at around 230 degrees. That's when you need to be concerned about the temperatures. I've hit 230-240 on two separate occasions due to part failures with no long term damage though as it was very brief. Transmission temps have to be very, very high to turn on the A/T Oil light on the dash.
326WHP 347TQ
Old 04-15-2021, 12:33 PM #9
I think the FSM trans temp range is for the oil pan temp. Not the fluid temp as it leaves the trans.
Old 04-15-2021, 01:03 PM #10
cl4Rk's Avatar
cl4Rk's Avatar
Trans temps
Interesting. Thanks for the info. Seems odd to me that the FSM would list a temp range for the ATF at a location that’s different from where the thermometer is located (and thus reported by OBDII). I’m not saying you’re wrong, only that it seems odd.
I had always just assumed the OBDII temperature data was the correct data to be used when using the FSM to perform temperature-specific diagnostics and procedures.
I’d love to learn more about this..
Could this be a FSM difference between earlier 3rd gens that don’t report the ATF temperature via OBDII, and later 3rd gens that do?
@Y2K_4X4
Old 04-15-2021, 01:31 PM #11
Real Name: Blair
Real Name: Blair
Totally agree - shit makes no sense. Just take good care of your fluids and filters. My engine runs nice and cool in all conditions. Transmission temp is bipolar.
Old 04-15-2021, 01:38 PM #12
Trans temps
It makes no sense why they would post an unrealistic temp range. I personally think it more important to see the trans pan oil temp. That is the oil after the cooler and what helps maintain the internal parts temperature. The sensor is sensing the fluid temp as it leaves the torque converter. It is the highest heat load, most variable and the last item in the fluid path before it leaves the trans if I understand the hydraulic schematics correctly.
Unless you’re *****-footing it on flat roads and running in lock up all the time it be tuff seeing the temp at that sensor constantly below 176f.
Old 04-15-2021, 01:46 PM #13
- 158-176 F for ATF
That's a reasonable 'normal' range for coolant, though engine damage won't start until much higher than that. When the cooling system is 100% working, it will almost always be between 188*F and 193*F unless the situation is extreme.
The trans temp is the range used for checking fluid levels, but it will vary quite wildly from that. There is no thermostat or anything to help control the trans temps. The trans temp light on the dash will come on at ~285*F/140*C.
The temp sensor for the trans is on the fluid outlet to the cooler. That's why the temp drops so quickly when the torque converter locks.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-15-2021, 02:16 PM #14
Yep, the TC is the highest heat load and the last in the path because of it.
4th , i’m , point , temps , trans
Engine Coolant and Trans Temps DMX512 4th Gen T4Rs 17 12-27-2019 07:36 PM
PID for trans temps on our 5th gens jpachard 5th gen T4Rs 2 09-17-2017 11:42 PM
OD trans temps 3bears 3rd gen T4Rs 6 09-28-2016 08:33 PM
What i learned about big hills & trans temps jgue467 3rd gen T4Rs 6 07-07-2014 01:46 PM
Normal Coolant/Trans temps? tenro1 3rd gen T4Rs 10 04-03-2014 11:54 AM
