Originally Posted by 19963.4lsr5
I think the FSM trans temp range is for the oil pan temp. Not the fluid temp as it leaves the trans.
Interesting. Thanks for the info. Seems odd to me that the FSM would list a temp range for the ATF at a location that’s different from where the thermometer is located (and thus reported by OBDII). I’m not saying you’re wrong, only that it seems odd.
I had always just assumed the OBDII temperature data was the correct data to be used when using the FSM to perform temperature-specific diagnostics and procedures.
I’d love to learn more about this..
Could this be a FSM difference between earlier 3rd gens that don’t report the ATF temperature via OBDII, and later 3rd gens that do?
